Tool Talk Discussion Forum
Wire welder
Heat Houser
02-20-2008 17:59:35
I am considering going to wire instead of stick and have zero experience with wire. I see there are a couple of different shielding gasses, CO and Argon. What are the advantages and disadvantages of each? Is one preferred over the other for different base metals, example aluminium, stainless, etc?
Thanks
Goose
02-21-2008 12:33:07
 Re: Wire welder in reply to Heat Houser, 02-20-2008 17:59:35
I have MIG, oxy-acetylene, and stick, all three, in my shop, and they all serve their own purpose during the course of a day's work.
Mike M
02-21-2008 11:53:10
I bought a Lincoln SP100 when they first came out. I find I use it all the time for all kinda stuff. Only regret is I should of maybe bought a bigger machine. I still use the stick for heavier stuff. I use CO2 and get by allright. Salesman said for what I do it should be fine and it last longer as it regenerates. The newer 110 machines are to be alot better than my old one so they tell me ? I thought about upgrading,but my old one is still going fine. I don't weld as much as I used to.
Jax
02-21-2008 10:18:45
On my welder, using Flux-Core wire requires you to change direction of current (wire gets negative not positive
jose bagge
02-21-2008 03:31:10
run argon-CO2 mix for normal steel welding, Argon if you are doing any aluminum, and no gas required for flux core.
jonjon
02-21-2008 00:51:39
I run argon with bare wire and co2 with flux core you can switch but co2 for the bare wire makes a crappy weld and burns hotter.
trucker40
02-21-2008 07:56:39
 Re: Wire welder in reply to jonjon, 02-21-2008 00:51:39
Sure you are entitled to your opinion but did you not see what I posted?Either you are a gas salesman,or just dont know much.Argon/Co2 mix is overrated.Flux core wire costs a lot,and it has its own problems mainly with slag in the weld.If you want to weld with flux core you might as well get a buzz box,save 800 dollars,and a lot more than that when you buy rods instead of rolls of high dollar wire.Were you replying to his question or trying to sell Argon/co2 gas and flux core wire?
jose bagge
02-21-2008 03:29:26
why do you run any gas with flux core?
trucker40
02-20-2008 21:21:19
Mig is good because you can weld thin metal all the way to about whatever thickness you can with a 225 amp Lincoln buzz box with a good 220 volt machine.Trouble is that good 220 volt welder costs a lot of money.If you look hard,maybe you can find a good 220 volt Mig and one bottle for a Thousand dollars,but its more likely to be 2 Thousand.You could get lucky and find it for less.So right there unless you plan on using it to weld a lot,and that means a lot of thin stuff,it maybe wouldnt be worth it.Now if you had a muffler shop or a body shop you wouldnt want anything else.If you want to do some fabrication with 1/8 to 3/8 steel,its the thing to use,and you can weld a big pile of iron in a day,and you can weld bigger stuff with multiple passes,just like you can with the buzz boxes.The welds are nearly the same strength as 7018,and penetrate deeply,which 7018 does not necessarily do.If you want to weld a lot of one pass welds that have deep penetration,are going to do the welding inside a shop,and need the range of from thin to thick metal,thats the best you can get. I dont know exactly what a bottle would cost,but the last bottle of Argon/co2 mix I bought was 60 dollars.I have not bought CO2 for a couple of years but I hear its a lot less.I have 2 bottles because I have a spool gun to weld aluminum with and they cost 125.00 each to rent on a 20 year contract in the last couple of years.You must use straight Argon to weld aluminum.CO2 for steel.Co2/argon mix is better for body work,but CO2 will work.Co2 makes a little more sparks,but if you get it set good and you know what you are doing,and you wear welding sleeves and good gloves you can weld all day and barely notice.A good thick material work shirt made out of cotton will work,it just gets burned up kind of quick.Sure Argon mix has advantages,but its kind of overrated I think.There is a lot to learn about any kind of welding.If you want a Mig get you one.Ask lots of questions.If I see your questions I will try to answer them,but others will as well.It helps you a lot to go watch somebody weld with a Mig,using a helmet of course.It took me about 30 minutes to make a weld with one when they taught me.If you watch me,I make it look easy.Its not as easy as it looks.It takes lots of practice,but most people can do a decent job of welding with a mig without a lot of trouble. The biggest thing is setting the machine right,you have to know that.Also after you learn how to keep the machine running helps.You need to do some maintenance about every time you use a Mig.They can get aggravating too.
Bob Huntress
02-20-2008 20:36:15
If you are planing to use the wire feed welder to replace the stick on basic steel repair project, may I suggest considering flux core. I've found that when welding outside, the wind tends to blow gas away from your work, such as when welding out in the field. It has a great deal more splater, but for farm equipment, it generally does acceptable work. I wouldn't want to do auto body with flux core, but you can still use gas sheilding in the shop if you wish. If you are looking to do aluminum or stainless, disregard what I said and use the gas. By the way, TIG is very difficult to learn. If you can do a good weld with a stick, you should find wire even easier, once you get use to it. TIG requires alot of practice, and expect to recieve many minor shocks from touching your filler rod to your tungsten. Trust me, it won't usually kill you, but it can be very frustrating. It took me months of constant practice to lay a decent bead before the chief would let me do any TIG jobs, and I was outstanding with stick welding. Because I was a proficient carpenter, the Coast Guard was traing me for cross rating to DC, which is the welding rate. That is the only reason that I spent so much time practicing TIG welding Aluminum. So, unless you are planing to weld aluminum boat hulls for a living, you might want to think long about TIG.
MarkB_MI
02-20-2008 18:42:07
Unlike TIG, which uses a single gas (typically argon), MIG requires different mixes for different metals. If you really see yourself welding a lot of stainless or aluminum, you probably want to go with TIG.
CO2 is not an inert gas and adds heat to the reaction. Good penetration and cheap but lots of spatter.
CO2/Argon mix is a compromise between penetration and spatter.
Stainless shouldn't be welded with a mix containing a lot of CO2 because the carbon will react with the chrome so that the resulting alloy is no longer stainless. A tri-mix of argon, helium and oxygen is often used for stainless.
Straight argon can be used for aluminum.
old
02-20-2008 18:13:55
Wire welder is ok for the small stuff unless you buy a high dollar unit. co/ar gas is good for steel welding but you need agron only for the alumian welding. For the most part unless you have a $10,000 machine a stick its a good bit stronger then mig. Mig is fast and easy but not as good for a lot of things. By6 the way this is from a retired welder that has done stick, mig and tig
