Tool Talk Discussion Forum
Cold weather
Jimdril
02-20-2008 10:03:23
Twice this year I've been unable to start the 8N. It'll turn over, slowly, but fast enough where she should start. It seems like it's maybe flooded. Any tips on cold weather starting?
Joe in MN.
02-20-2008 16:16:24
 Re: Cold weather in reply to Jimdril, 02-20-2008 10:03:23
I'm thinking of moving to a warmer state --- how bout you ????
Duke(WNY)
02-20-2008 15:12:42
Try warming the intake maifold with a hair dryer for about 5 minutes - works with my 8N.
Bob
02-20-2008 14:55:16
Find a "headbolt heater"! ("Flatty" V-8 head shown. I had one in an 8N Ford I used to own. I wish I would have kept the heater.)
Third Party Image
Third Party Image
Third Party Image
Circus
02-20-2008 12:53:43
 Apologize if obvious in reply to Jimdril, 02-20-2008 10:03:23
Biger battery, engine heater, ether (sparingly), gas line treatment.
Bob - MI
02-20-2008 12:27:18
Try keeping the clutch disengaged. It"s amazing how much drag the oil in the trans. and the pump can create. It will spin a little faster and that may be all you need.
I also will turn it over a few times without the ignition on to help prime the cylinders. Old motorcycle trick that works ok.
If you think you may have flooded it you may want to put in some new plugs.
My 2N (6V) gradually got worse starting in the winter and I finally traced it to a bad ignition switch. Starts way better now with a new switch and new plugs (AL-437).
8N'r--WI
02-20-2008 12:03:20
Jim---just for fun, leave your ignition switch off, pull the choke all the way out and turn your engine over about 4 times.
Now, turn your ignition switch on, pull the choke out, and try to start it.
That works for one of my N tractors on really cold days (below zero). It will start right away with this method.
I have a few N Tractors, and they all seem to have their own personalities on cold days.
Tim
old
02-20-2008 11:55:59
Could be as simple as weak spark. What I would do is check the spark and also pull the air tube off the carb and double check if its is flooded. If it is replace the spark plugs with auto=lite 437s and try again. The N series tractor are well known for gas fouling the plugs and when that happens they will not start. I would not use starting fluid on it because it can be hard on the engine
Balatonm
02-20-2008 10:08:06
Starting Fluid, have you tried pullstarting it?
bellyacre
02-20-2008 10:21:56
 Re: Cold weather in reply to Balatonm, 02-20-2008 10:08:06
Balatonm Welcome home! Ya find this weather a bit more refreshing than New Orleans? Hope ya had a good experience down there, sounds like the others did.
Balatonm
02-20-2008 10:33:14
 Re: Cold weather in reply to bellyacre, 02-20-2008 10:21:56
Loved it, great food, friendly people, warm wearther, everything you could ask for. I'm ready to go back any time.
