Cutting up old farm equipment
Mike
08-14-2001 05:35:06
Sorry for the basic question. I'm new to this and in WAY over my head.
I just inherited some property in upper NY state and in the process of walking through it, found out that someone had dumped (along time ago) tons of old farm equipment. This is the rusted stuff, looks like old harrows, a tractor, old boat trailer etc.
I assume that it's steel. The question is, what would I need to effectively cut this up so I could haul it away and is there a market for scrap metal that's rusted?
I have a compressor and know how to use air tools. Could I use a die grinder? A air reciprocating saw? or do I need high skill stuff like plasma cutters and the like. If I need a steel cutter, I'd be in way over my head unless they're easy to learn how to use.
I have a 12,000 lb winch on my truck so moving stuff around should not be too difficult and a 5x8' trailer to haul it away to a scrap yard if that's appropriate.
Again sorry for the basic question, but I'd be grateful for any direction or suggestions.
Thanks
Mike
mailto:[email protected]
Chris
08-14-2001 19:53:37
 Re: cutting up old farm equipment in reply to Mike, 08-14-2001 05:35:06
I don't know your best method of removal but I wanted to throw in another cutting device. A gas powered cutoff saw. It's a chain saw motor with large metal cutting wheel in front--you can rent them from tool rental shops. I'd still watch for fire from the sparks it throws when cutting.
John in MA
08-15-2001 16:17:28
 Re: Re: cutting up old farm equipment in reply to Chris, 08-14-2001 19:53:37
Those are a lot of fun to use. There's something very cool about cutting through steel with a gas powered 12" SiC wheel.
Unfortunatly they're, noisy, somewhat slow, and the abrasive wheels don't last too long. They're great if you need to carry it around a lot, but you'd use quite a few wheels cutting up all of this guy's stuff.
Mike
08-14-2001 12:17:10
Thanks guys for all the great tips. I hope I didn't offend anyone when I said cut up the old stuff, but trust me, none of it would be salvageable in my opinion.
Based on all the suggestions below, I'll put an add in the local paper for free stuff and contact scrap dealers after that.
FYI - since several of you asked, it's in Bainbridge NY.
Thanks again, it's appreciated.
Mike
paul
08-14-2001 16:48:02
 Re: Re: cutting up old farm equipment in reply to Mike, 08-14-2001 12:17:10
I agree old busted up boat trailers, etc. are not worth much to anyone. Old rusted out combines aren't worth much, and old harrows are a dime a dozen...
However, I am amazed at what people will pay for an old tractor sitting in a grove for 30 years. Wheels rusted, a few parts missing, engine stuck tight, radiator shot (or missing), fenders bent up - and it will still bring $200.
Also, if you would happen to stumble across a _cast_ iron implement seat, those bring $50 - $1000 depending on what model it is. Just amazing.....
Plows & 2 row corn planters seem to be most popular now a days, you might want to check for such - even if they are not complete, the parts can be worth something to folks that collect them.
I'd hate to see you lose out on something valuable or get 'taken' on a 'pick up free' deal.
--->Paul
Greaseman
08-14-2001 11:59:28
Depending on where in N.Y. you are, you may have couple options. Option 1)contact one of the local salvage yards to ask about the removal of the "waste product".
Some will send a 40 Yard dumpster and you can fill it yourself at your convienence. If you have to cut it up yourself, try a hand held torch (propane) as it will be easier to handle. Bring a FIRE EXTINGUISHER WITH YOU! Option 2) you could have a junk dealer come to you, but I had one come in and they only took what they wanted plus some that I didn't want taken; but they will make you probably pay for them to remove it and you never know what their doing with it. My Buddy had some taken away and turned out the scrap dealer was taking it to another field and we then had to "re-clean" the second field or otherwise some hefty bills.
paul
08-14-2001 09:56:25
You are brave, asking this group about cuting up old farm stuff! :)
Anyhow, would any of it be salvagable, I would try to sell out the items that have some value, such as the tractor. Old plows are also desirable, worth $25 just for the coulter clamps on them, etc. It will take time & hassle, but might be worthwhile?
The iron market is in the dumps for the past 5 years. If you just have to have it hauled out, yes you can sell it, but you don't make anything on it. If you can wait a few years, the scrap iron prices may go up. Just a thought.
A cutting torch is the way to go - oxy & propane or acetilne (oh my, my spelling is horrid!). If you want to do it yourself.
Iron is heavy, gasoline to haul it is expensive, iron is cheap. Forget your small trailer - you want full loads hauled, the iron yards pay more for big amounts, not a few 100 lbs at a time. Also, it used to be that you could sort the iron, cut it into the proper size, etc. and you would get a lot more money. Check this out before starting, can double your money by doing it right. Altho this does not seem to be so important any more.
Years ago at auctions scrap cutters would bid on piles of iron in the grove. But with the depressed prices, not much any more.
I would look into finding a scrap dealer to pick it up for you. You might not get paid anything, or much with the low iron prices, but you won't get much by the time you buy a torch & trailer & gas... The hassle here is finding a good person that treats you right, cleans it all up, pays you right, etc.
--->Paul
ROD
08-14-2001 08:27:38
IT WOULD BE ASHAMED TO CUT UP GOOD RESTORABLE FARM EQUIPMENT. I'M SURE THERE ARE SOME RUST HOUNDS IN UP STATE NEW YORK THAT WOULD COME AND TAKE THAT STUFF OFF YOUR HANDS. BY THE WAY TORCHES CAN BE PROPANE AND OXYGEN TOO. LESS EXPENSIVE THAT WAY. WORKS WELL FOR JUNK CUTTING AND YOU ONLY HAVE ONE BOTTLE TO RENT OR BUY. GOOD LUCK.
Jerry B
08-14-2001 07:10:22
You might have some luck getting the word out that there is an old tractor that can be bought cheap IF there is enough to work with AND it is a desireable or rare tractor.
Just a thought.
Jerry A.
08-14-2001 06:52:30
Check out the prices on decent size cutting torch and tanks. Might pay a visit to a local welding shop and pick their brains on the equipment you would need. Like the other post mentioned, be safe with the clothes you wear and keep fire suppression handy.
It's actually fun to cut up stuff like that, if you have the time.
Dean
08-14-2001 05:49:10
A gas torch with a cutting tip will do the job, not much skill required. But you have to do it safely, like eye protection (goggles) and fire protection (a helper with a good supply of water). Having said that, I'd still like to suggest you do it another, much safer, way.
Contact a scrap dealer. If you really have "tons", they may come out and haul it all away for you. You likely won't get paid for it but you'll get rid of it. Rust is not an issue. If you do this, make sure they understand that they have to take everything, not pick and choose what they want.
