Q on welding aluminum
kev
08-13-2001 21:28:26
Im tring to weld some aluminum (a transmission case)with a mig welder
and im using argon gas and .35 aluminum wire. But the aluminum just builds up on the wire and won't melt into the work peace. Any help (to tell me any techniques I should use) would be appreciated..thanks
kelvin wynn
04-16-2002 15:00:54
 Re: Q on welding aluminum in reply to kev, 08-13-2001 21:28:26
What is some of the advantages/disadvantages of welding aluminum when rivets, nuts and bolts can be used.
tony
08-15-2001 20:32:24
another thing that might help would be to clamp your two pieces together tight, and then use a grinder on the joint to make a V. put your weld in the V and then grind it down flush with the pieces, this worked great for my cast aluminum pedal tractors
Steve U.S. Alloys
08-14-2001 06:55:14
If this trans case is not automotive you could be dealing with magnesium. Al wire will not affinity to magnesium. Shave a small sample off the casing and put the torch to the shaving. If it is magnesium it will burn very brightly. Be carefull as the magnesium will burn until completely consumed. Don't let it get next to anything flammable.
If you do have Al, as Mark says, some types are considered difficult to weld and some are considered to be unweldable. I don't think any of those are used in the automotive industry but who can really be sure anymore? So much depends on the country of origin.
You may need to put a bit of preheat into the part before trying to weld it. Make sure the ground is adequate as well. Truthfully though, it sounds to me like you may not be dealing with Al at all.
Mark Kw
08-14-2001 06:01:13
Reverse polarity, 16 to 21 volts, wire speed around 80 to 150 inches per minute. Clean Clean Clean. AL needs to be spotless in order to get any kind of weld to stick to it. If this don't work, best be ordering a new one because some AL castings just will not weld at all no matter what you do. If it's just a dust cover or similar with no stress on it, you can try some of the AL solders (see prior post about AL welding on this MB)
Mark Kw (additional)
08-14-2001 06:02:43
 Re: Re: Q on welding aluminum in reply to Mark Kw, 08-14-2001 06:01:13
Pure argon gas running 40 to 60 cfh too. Not enough or too much gas will cause problems too.
Branden
08-15-2001 09:19:19
 Re: Re: Re: Q on welding aluminum in reply to Mark Kw (additional), 08-14-2001 06:02:43
You need to clean it very, very, very clean AND..... ..you will also need to do a preheat as well. I have no idea what grade or series they are using for that automotive stuff. I think in all likely hood since it is cast aluminum, you may not be able to do it that great at all. Someone with aluminum cylinder head repair experience would be a good source of information. Call a machinist in your area, who does repairs on aluminum cylinder heads, he might be a wealth of good information.
Branden
