Tool Talk Discussion Forum
Troy-bilt tiller
Todd in SE Ohio
02-18-2008 18:55:39
Trying to get a jump on spring, for once and I need some assistance. My parents have an older Troy-bilt tiller, don't know the model name, not even sure if they had names when this one was built. We got it used in the early 90's. The main problem I have with it is I can not get the belts to stop slipping when breaking new ground. The only way I have found to keep it from slipping. is to bungee the fwd/rev handle to the depth adjuster, which makes trying to stop and turn a real treat. Can anyone out there tell me how to tighten or adjust this machine? Dad replaced the belts on it just a few years ago, and it really only gets used once or twice a year, if that helps any.
T.R. in Florida
03-23-2008 12:45:54
 Re: Troy-bilt tiller in reply to Todd in SE Ohio, 02-18-2008 18:55:39
I also have an older horse that I inherited, it is a 8 h.p. Briggs and Stratton and I am having difficulty locating the serial and model number, I have found some numbers on the handle at the base, Garden Way TH-1019 with 5713779 under it. Also on the side of what looks like the drive case TH1001-1 with 872279 under it. If anyone has any ideas as to how I can identify this machine it would be greatly appreciated as it is in need of maitenence and I need to buy parts. Any ideas where the best place to locate replacement parts is?
4J
04-11-2008 20:57:44
 Re: Troy-bilt tiller in reply to T.R. in Florida, 03-23-2008 12:45:54
Hello, To the best of my knowledge this is a Troy-Bilt "Horse" model. I have just recently aquired the same model you described and am searching for a worm gear myself. The serial number should be stamped on a lip of the transmission on the right side as you stand at the controls. I had to scrape a bunch of crud off mine to see the number. When getting parts for the engine there are 3 numbers on the hood above the recoil string, that you will need for any internal engine parts. I found that my local small engine place had the older books and parts lists, and should be able to get parts. You may try the same. Hope this was of some help.
Cummins 1955
02-20-2008 14:20:56
Ours last spring was doing just what you decribed. We decided the spring thant pulls back in the "latch" was weak. We tried pretty much everything metioned above to no avail. A new spring solved the problem. We got it at TSC.
Cummins 1955
02-20-2008 14:20:48
Leland
02-19-2008 16:32:37
start out in the second or third notch on the depth bar and work your way deeper slowly pass after pass ,and the easist way to properly adjust belts is loosed the bolt on the handle lock push belt bar down to snug belts then tighten bolt back down .are the pullys rusted or worn ? are you buying the right lenth of belts ? and most of all did the come from troy bilt there belts out last all others .
jdemaris
02-19-2008 05:58:31
There's an adjustment, but even so and with new belts they are going to slip if you try to break very hard ground. In my opinion, the Troy Builts are crap - even the best dual-belt Horse models. We used to sell them and rent them out. They're fine in gardens used every year, or in soft or sandy soil. But, in breaking sod on hard-pan or muck or rocky soil - they are awful. And even worse, you cannot run the wheel drive independently from the tiller drive.
The Troy Built tiller is a prime example of good advertising with an inferior product. We gave up on renting out Troy Builts and went over to Hondas, Ariens Rockets, and BCS units - all worlds better than anything Troy Built ever made.
That being said, a Troy Built can last virtually forever if you take care of it - it just will never work as well as some other - much better machines.
55 50
02-19-2008 09:19:41
 Re: Troy-bilt tiller in reply to jdemaris, 02-19-2008 05:58:31
As does Mike M, I agree also. Your "prime example" statement is right on. I once bought a used Troy-Bilt. Kept it only ONE season and it was traded for a new Ariens front-tine model. Even the front tine unit was better than a Troy-Bilt. I absolutely hated to turn it around without a differential in the drive wheels - a terrible design. In advertising they often showed a lady guiding it in a straight line with one hand. Fair enough, but also tell the prospective customers that ONE lady with ONE hand will never turn that thing around at garden"s end!!!
IH2444
02-19-2008 07:28:15
I have had a Horse Troy Built tiller since about 71.
I never had any trouble with the belt slipping. And yes they are not good at breaking up new ground.
But then most small tillers are not good at that.
A good turning plow or 3 point tiller are good for new ground.
Use the right tool for the job.
m schmidt
03-06-2008 17:44:28
 Re: Troy-bilt tiller in reply to IH2444, 02-19-2008 07:28:15
hello, i have had my 8hp horse troy-bilt tiller since 1982. i bot it new. i am very happy with it. it does not sit outside. it has made many seedbeds for me. some in untilled soil. it runs like a champ, and simply stated... "does the job!" i also use it to power my PTO troy-bilt log splitter, in fact, i split up a cord of oak with the system yesterday. i do all the maint to my horse, and am still in awe of it. regards, ms
jdemaris
02-19-2008 07:46:25
My point was - and still is - there are several tillers that break up hard ground much better then any Troy Built. Also, many other models allow the wheel drive to work while the tiller-drive is not engaged.
I've lived in hard-ground areas for over 50 years in New York and northern Vermont. Maybe if I lived in a soft-soil area, I wouldn't have noticed how much better several other tillers are - as compared to any Troy Built.
Yes, I agree about using the right tool for the job. But, for some small plots, it makes a lot less mess to turn new ground with a good tiller, instead of plowing and disking with a large tractor.
Billy NY
02-19-2008 09:54:00
 Re: Troy-bilt tiller in reply to jdemaris, 02-19-2008 07:46:25
I dunno, hard packed dry soils can make the job quite difficult with a walk behind, no doubt there.
If you take your time and your tines are not completely worn out, you do have to make a lot of passes, drop down one notch at a time, and if it is so dry and just makes dust, why even bother just not worth it the way I see it. Now if other machines perform better, good to know that if you have difficult soils, and no doubt money better spent on one.
Breaking ground is so much easier with these when there is sufficient moisture in the soil, and you have to use some common sense, by tilling in mid to late fall, early to mid spring, or do what a lot of people do here, just dedicate a space for a garden, then excavate out the clay/gravel and re-fill with good organic mix suited for a garden, it makes it so much easier on the machine,and makes a much better garden to work with.
I've used a Troy Bilt horse for over 20 years, and no they don't take the all the work out of the job in the soils here, but they are a strong durable machine as I can attest to having worked some tough areas with one, at least the horse 8hp kohler model is. If you can change your soil out like I mentioned, to something better suited, and we're talking garden size plots here, this is a great machine to use, the job is made so much easier and of course some areas with better natural soils are not so difficult work with, in which case I still think these perform with acceptable results. They still require effort from the operator, and may not be the most pleasant to operate at times. Rocks are fun when you hit them in high gear with a T.B.,they will pull your arm out of the socket sometimes ! They also like flat ground, fighting a slope makes the job even more difficult.
I'm sure by now and even then, there must be a better walk behind rear tiller, the TB design is an old one, also would have liked to tried out others myself, as I've kept a decent sized garden for many years, a tiller is nice thing to own even if it's a troy bilt.
On this model, the tines can be disengaged while the drive wheels are turning, I'd hate to have to walk one of those up on planks into a truck with the tines spinning, I can see your point there, bad design and a safety hazard if they can't be disengaged.
IH2444
02-19-2008 08:54:58
The later model Troy Builts do have a tine disconnect feature.
Just like later tractors have live PTO and 3 point hitch...
jdemaris
02-19-2008 09:24:04
 Re: Troy-bilt tiller in reply to IH2444, 02-19-2008 08:54:58
I'll take your word for it, but can't say I've ever seen one being used. Troy Builts are no longer the fad in my area, and I don't see evidence of anyone selling them around here. I live near Troy, New York and used to pay attention since "Troy Built" was once a local entity. But, they've gone bankrupt so many times, and changed hands so often, I kind of lost track. I've got four Horse Troy-Builts sitting in my barn, and couldn't tell you what vintage. Two with cast-iron Tecumsehs, one with a Briggs, and one with a Kohler. I've also been out of the consumer-level lawn & garden repair business since 1991. By 1991 we had long stopped renting Troy Builts and only used BCS for rental units. I remember the Horse dual-belt model coming out in 1967. The Horse II single-belt came out in 1978 and that's when we stopped renting them out.
At that point, Troy Built seemed to be going the same direction as Homelite saws - just selling consumer junk. The Horse III tine-clutch model came out in 1982 or 1983 - but by then, I never saw one being used or sold - just saw the paperwork and advertising.
Usually with a woman tilling with only one hand on the tiller. Boy - was that a joke - at least in New York hard-pan soils. So, there was Rototiller Co. - to Watco - to Troy Built - to Gardenway - to MTD - to nowhere - and now? I couldn't tell you. I've still got a couple of original Rototillers - actually I've four of them. Extremely rugged machines but not very user-friendly.
IH2444
02-19-2008 09:54:45
 Re: Troy-bilt tiller in reply to jdemaris, 02-19-2008 09:24:04
Yeah the one handed operation ad was a joke.
When did the BCS tillers come out ? One thing for certain the Horse tillers were much better than the front tine beasts.
And yes I did not like that the blades kept spinning either.
IH2444
02-19-2008 10:01:09
 Re: Troy-bilt tiller in reply to IH2444, 02-19-2008 09:54:45
I used to have an old 5hp front tine tiller I called " A Tiller the Hun" It was a barbarian and would kill ya using it in new ground.
Mike M
02-19-2008 07:20:16
I think you are about the only person I ever heard speak badly of a Troybilt. And let me say I 100% AGREE !!!!!
Dad has owned one since the 70's and I never thought much of it. As part of their poor design they are TOO TOP HEAVY and will flop over on you even on a very small slope.
I once saw a cut away of a BCS and I was sure impressed with the design and quailty of those units. I never have ran one though. We don't do much tilling so barely use the Troybilt either. Mom does about all her tilling needs with one of those small Mantis tillers. She loves that thing ! I have used it some too on small reseedings in the yard. I like it too. Best of all it just keeps going and I don't have to fix it.
supergrumpy
02-19-2008 05:25:02
search the archives down in garden tractors, lots of tiller posts there, Leland and El Toro love these machines
MTD bot Trot-Bilt assets from Garden Way when company folded, all the manuals are free on-line at Troy-Bilt website, under manuals use "horse" or "pony" and "1" as serial number
horse is big sturdy unit, pony is much smaller/lighter with reverse drive off camshaft
older horse units use dual belts
El Toro
02-19-2008 05:14:56
third party image
You would be better off to plow the ground then use the tiller to work the plowed ground. The single 1/2" belt won't take that load. I use the Gates Greenstripe 6822 belt since they're made to take the clutching and declutching. Cost is about $11.00. Hal
old
02-18-2008 20:43:43
You say a few years ago as far as replacing the belts. It doesn't take but a couple years for the belts to go bad just from sitting around. Belts that slip go bad faster then ones that don't because they get hot and heat does bad things to belts as does sun light
ldj
02-18-2008 20:10:58
Go to Troy built web site. Probably can down load manual
Billy NY
02-18-2008 20:08:34
Yes, there is an adjustment. With the lever in forward, the clutch roller (it rolls on a trapezoid shaped block that is adjustable, down is to tighten, up is to loosen the belt) it should be 1/4" to 5/16" between the bracket that holds the block to the clutch roller. An easy tool/guage can be made out of a piece of 5/16" round stock, with an end machined/ground flat that is 1/4" thick. If the 1/4" (flat on one side) does not fit, it is too loose, if the full 5/16" + fits between the roller and block it's too tight. You might not have to move that block down that much, trial and error kind of thing, you will get it where you want it, don't really need that tool/gauge, but it's very easy to make one.
Also make sure the linkages and pivot points are clean and lubed prior to doing the adjusting mentioned above.
The pivot with the castellated nut on the end that the speed lever pivots on, that you use to change speeds, make sure that it is properly adjusted, cleaned, and lubed etc. There is a sweet spot with the tightness of the castle nut, too tight, will be hard to operate, too loose it won't stay in gear, if that lever binds you can break the bracket, I had to weld my fathers, as it was going to snap, kind of a weak point when that lever starts to bind. He let his sit out too much, things rust and bind up.
The above information was out of a 1985 owners manual for an 8HP horse model pto model.
These were great rear tine walk behinds, made right here in Troy, N.Y., I can remember going to their parts counter and used to deliver there too, lot of people lost jobs when they were uprooted to wherever they went 10 years ago. Not sure, you may find information about them or be able to get an owners manual from the manufacturer.
Another tip would be to service any oil compartments, gear case, engine etc., condensation from temperature changes may build up water in these components, just like a rear end on a tractor, pull the plug and the water comes out first. I'd flush the compartments with kerosene and refill with fresh lube.
Ralph A. Detrow
02-18-2008 19:31:30
If I remember correctly, the 5 HP Pony model uses an odd-size belt. If you don't get the proper size it will slip easily. About the only source for the odd belt used to be Troy Bilt. Don't know if they still sell them.
Das Unimog
02-18-2008 19:15:19
If it's like my model there is an adjustment on
the lever that engages the belts or moves it in reverse. At the bottom of the lever there is a
9/16" bolt that you backoff to finger tight and use a screwdriver or prybar to move the mounting
block adjuster up or down as needed to tighten
the belt or belts. I think the block has to go
down to tighten but can't really remember without
seeing it. Hope this points you in the right
direction.
