Tool Talk Discussion Forum
OT Kawasaki 300 4x4 Blows fuse?
deerly parted
02-18-2008 12:51:33
I have a 1992 Kawasaki 300 4x4 that has been running great until a couple days ago. My son was riding and it all of a sudden died. It wouldn't start. I found the fuse at the battery was blown. I replaced the fuse and it blew again as soon as I turned the key to start. Not sure where to start but I need a wiring diagram if anyone has one. Let me know and I can get you my email address. Thanks
Tom/Idaho
02-19-2008 09:29:28
 Re: OT Kawasaki 300 4x4 Blows fuse? in reply to deerly parted, 02-18-2008 12:51:33
I have a wire diagram for a Kawasaki 220 that might give you an idea where to look. I can also send you a forum address similar to this one that deals with ATVs and has a good board on Kawasaki. [email protected]
504-2
02-18-2008 14:35:53
There is a hot with the key on extra wire under the seat and look above the rear end and below the tail light and you will find the solenoid check the wires there too.
Fawteen
02-18-2008 13:37:15
First thing to do is take off all the plastic you need to and do a very thorough visual inspection of the wiring harness. Chances are it has rubbed against something and worn through the insulation.
