"Well I don�t know, this will be my first! Remember you live in an area that is as flat as the top of my head! Now where do I live? LOL" You sound just like me when we were moving to AZ. I told the wife that once we get passed Las Vegas, "it's all down hill and flat". Wow did I ever get the shock of my life. AZ is much like WA or Co but the mountains are not as long nor steep. My fish'n hole has a 14% grade into it...lol AZ is anything but flat in 80% of the areas. GN hitching is just like bumper pull hitching. You have to practice backing up to the ball and then adjust for forward/aft ball location. With a 5th hitching then you get close side to side then back up until the king pin slams home and your done. You can be off 2" side to side. When the pin latchs tells you to stop backing. A simple one person hitching without getting out of the cab until your ready to finsih final hitching duty's (raising the landing gear, electric connection, etc). Most new 5th designs are self king pin locking, rotate side to side so they work well in ruff terrian but are slightly more side to side stable while pulling than a GN. I'm going to modifiy my 5th bolster plate to be a 4-pin removal so my bed is clean other than a 1" high connection rail so it would have the benefits of GN hitching has. CW= Camping World
"Jack was also saying with all this uneven ground here a single jack in the center of the trailer is better than two jacks on each side! Your thoughts?" To me that depends on if your ever going to leave your trailer loaded when unhitched. A dual landing gear will work much better as it's more stable as there's more support. The second consideration is the 5th/GN design puts more ground pressure on the pad from the "lever" design and even dual pads will sink after setting for awhile. I just like the dual jacks much better overall even on a empty GN/5th trailer.
In any event I would use a large foot pad, 8"x8", on the jack pad, then have seperate 14"x14" wood? pad for soft ground support. If the ground support pad is handy and there, you'll use it often. If the pad is stored away from the jack area then you most likey won't use it too often. The pad "slip in" tilted flat bar hanger design works well for pad storage. Most all the newer jack designs use a spring loaded bottom extension. This works well as then you first let out the extension then lower the jack. This keeps the jack pad raised high so you don't hit it on ruff terrain use. For no more than I use a winch, I would have bought a manual winch if I could have found one for a reasonable price. I caught Costco on sale for $350 delivered for a 8k winch so that made the decision easy :). I also added a couple $5 4-ton rated snatch blocks from Harbor Frieght. Your next mod will probably be "forward" self-adjustable electric brakes with a single 10k DRW axle w/oil bath bearings, about $400 from Dexter. Wow what a stable pulling trailer design :) T_Bone
