Tool Talk Discussion Forum
miller thunderbolt welder
akb
02-16-2008 23:34:16
Just bought a used thunderbolt ac stick welder.
What size breaker is normally used.
225 amp 220volt
Thanks
Bill-KCKs
02-17-2008 20:24:44
 Re: miller thunderbolt welder in reply to akb, 02-16-2008 23:34:16
If it was on a home-built cart with one melted plastic wheel hub, it might be the one that was stolen from me....not likely, but I just had to say something.
I ran it on a 50-A breaker with #6 wire. I liked it enough I found another Thunderbolt with DC.
fixerupper
02-17-2008 06:20:23
I've run a thunderbolt on a 50A for what seems like forever, and the breaker has never given trouble. Jim
s.crum
02-17-2008 06:04:19
These typically use a 50 amp line and breaker. I run a Miller Syncrowave 180SD on the recommended 50 amp. And sometimes an old (I mean WW2 vintage)Craftsman AC welder at up to 210 amps on the 50 amp.
hay
02-17-2008 04:09:05
i don't know if it is right but i put my miller thunderbolt welder on a 50 amp breaker. most of my welding is in the 70-80 amp range. so far i have not had any trouble 'tripping' the breaker at those settings. i also don't weld for more than 2-3 minutes before stopping to chip and brush. maybe a bigger breaker would be needed if welding exceeded 90-100 amps or longer time?
36 coupe
02-17-2008 14:06:48
 Re: miller thunderbolt welder in reply to hay, 02-17-2008 04:09:05
50 amps is the primary current when welding at 225 amps.The welder wont draw 50 amps primary current if you are welding at 50 to 80 amps welding.
Chuck UR
02-17-2008 03:12:31
If you didn't get the owners manual with the welder you should be able to download it from the Miller site.
http://www.millerwelds.com/service/ownersmanuals.php
akb
02-17-2008 11:29:24
 Re: miller thunderbolt welder in reply to Chuck UR, 02-17-2008 03:12:31
No owners manual.I thought about the website after posting here.
Thank you all for the input.
