Tool Talk Discussion Forum
Chain Saw
Sam from WA
02-16-2008 22:20:19
Because a coworker today almost got his leg in a pretty good sized chain saw, i wanted to say something about chainsaw safety. I have learned from presonal experience that an operator must always wear his gloves when using and sharpening a chain saw. One must also have a good, steady grip on the saw in case it kicks back and one must ALWAYS keep his legs out of the path of the saw chain if it comes off. My boss has almost lost his left hand from saw chains coming off.
I realize there are a few other things I have not mentioned, but these are the basics. I use chainsaws almost everyday at my work, and there are many things some of us more 'professional' operators do that a 'novice' would never do, both safe and unsafe.
Shovelman
02-17-2008 16:23:58
 Re: Chain Saw in reply to Sam from WA, 02-16-2008 22:20:19
I agree with 2x4, Chaps are a must, along with a good hard hat if you are in the woods. Any Stihl dealer worth his salt will have 6 or 9 ply chaps which range from $65 to about $80.
Pretty cheap insurance.
Billy NY
02-17-2008 13:22:01
I think about these things every time I fire mine up. One thing I could mention is to stay out of the trajectory of the chain and bar, as much as you can. Safety apparel, hearing protection and eye protection no question there, I don't own a pair of chaps, but will at some point soon, as I will be doing more wood. In the interim, I take my time, also have a good feel for my saw and keep the cutters sharp, am aware that when you start filing down those rakers, it increases the kick-back potential, not sure what kind of chains are more prone for this to occur. I think it's highly important to clear your work area and clean an area around a tree that your going to cut down before you start cutting. There probably is no limit to safe practice with these things.
Many times I don't run the saw wide open on the smaller diameter wood, I let the saw do the work, a sharp chain really helps, so if it did want to kick back at least I'm not going full bore, but by the same token not so slow it binds, catches or presents a danger, feels like you have more control than cutting through too fast and bumping the tip into something that could cause a kick back etc.. I use as much throttle as it seems to need for what I'm cutting. I find those annoying little saplings will easily catch and toss a chain at slow speeds, especially if it's loose, had that happen quite a bit with a Husquavarna farm boss my friend had. My Stihl ms390 seems to be a good match for me and has not tossed a chain yet. One thing to toss the chain off, but I cannot imagine breaking one.
I took a gouge out my shin from the chain once, the saw was not running I bumped into it !
Good reminder about safety !
Mathias NY
02-17-2008 12:24:06
Be aware that top-handle saws are not intended as one-hand saws. A few years ago I was pruning some cherry trees with a saw like that. I didn't need a ladder because I could just put one hand on the back of the saw and hit the trigger with my finger tips. Needless to say this wasn't the brightest idea I ever had. When the wind gusted it knocked the (running) saw out of my hands and ended up cradling it in my arms as it fell. Fortunately the chain wasn't turning and no other branches caught the trigger. I walked away with only scratches on my forewarms. Be Careful!!
patiolant
02-17-2008 08:46:31
After many, many years of heating with wood, the two major rules I live by when using a chainsaw (beyond wearing safety gear and monitoring chain tightness as already mentioned) are:
1. Always be aware of the position of the tip of your saw bar. Most potential accidents I have had occur when the tip of the bar touches something and either causes kickback or launches another piece of wood or debris into the air. Don't try to cut multiple pieces of wood at one time, since this usually means that your bar tip is going to contact something.
2. When tired, hungover, etc., put the saw away and do something else. Lack of concentration is a recipe for a disaster when using a chainsaw.
supergrumpy
02-17-2008 11:44:17
 Re: Chain Saw in reply to patiolant, 02-17-2008 08:46:31
AMEN on stopping when you lose your concentration
ericlb
02-17-2008 06:00:58
add in be sure to watch for a piece of the log kiking the saw back after you finish the cut, had that happen 5 years ago, the wood dropped after the cut was done kicked the saw tip into my left foot behind the toes, it was 3/8 skip tooth chisle chain, and no it wasnt stopped yet, i got used to the missing parts, but man those phantom verve pains go on to this day,wear your steel toe boots, not your regular ones!
2x4
02-17-2008 00:45:27
90% of chainsaw leg injuries are to the right Knee. A good set of ballistic chainsaw pants or chaps, which a saw cannot cut thru, is one of the best investments you can make. Several friends walk with a permanent limp because they didnt buy a set. The chain coming off & hurting anyone should not be a problem since all modern saws are equipped with 2 or 3 devices to stop it from whipping back. Unfortunately these often get cut thru and the operator doesn't fix them because he doesn't knoe they're there or their purpose.
