Tool Talk Discussion Forum
OT: Roof Repair
Bill VA
02-16-2008 16:29:57
We had some high wind and few shingles (asphalt type) blew off. Here"s my question.
I can figure out how to fix/replace the shingles, but how do you folks, once you are on the roof, keep from sliding off!!!!
Any special techniques you can share to keep from sliding over the edge, clothing, shoes, rope tied around the waist, would be appreciated.
Thanks!
Bill
Mark-Ia
02-17-2008 08:13:59
 Re: OT: Roof Repair in reply to Bill VA, 02-16-2008 16:29:57
You didn't tell us what roof pitch you were working on. A 4/12 pitch, you an walk back and forth all day and not slide off. 6/12 you will need roof jacks with a 2x6.
Michael Soldan
02-17-2008 06:23:41
I had two machinery shed roofs of steel that needed painting every once in a while, they had a steep pitch so I had two approaches. I would put the tractor bucket up to the eave and set the ladder up the roof from the bucket, very stable and I worked off of the ladder. Other times I laid the ladder up the roof and tied it over the other side to the tractor, either way the ladder didn't move, I could shift the ladder left or right several feet before having to move the anchor. Rubber soled running shoes work well on roofs, a safety rope around you is a good idea.
Stan in Oly, WA
02-16-2008 22:52:00
Hi Bill,
NE IA and Lee in Iowa both mentioned ladders already, but I don't think that suggestion is exhausted yet. A ladder is difficult to work from (though much better than trying to work from a hospital bed, which using a ladder as suggested can do a lot to prevent.) Roof jacks and a plank, as shown, are comfortable to work from but require that you lift shingles to nail where the nail holes will be covered afterwards. Lifting shingles in the winter can increase the size of your repair project. What you can do is combine those ideas by putting a plank (2X6 is big enough) between two ladders which are secured by ladders on the opposite slope of the roof, or with hooks which you can either buy or make out of scrap plywood or lumber very quickly. Ladders on each side of the roof provides the greatest sense of security but then you'd need two extension ladders to take apart, and probably one more to get on and off the roof. Most people don't have that many ladders unless they're roofers, but you're probably not or you wouldn't be asking a roofing question.
The way to deal with too few ladders is to do essentially the same thing using lumber instead of ladders. Nail the 2X4's or 2X6's together at the peak instead of using rope or chain, and if you're afraid that the nailing won't maintain the angle, run the boards each a foot or so past the peak and tack a gusset across so they can't straighten out.
Whatever system you use to keep you from slipping doesn't have to be very strong, it only has to not slip. It's not like scaffolding which has to support your whole weight. Be careful, though. This is one of those situations where the setup to do the job safely could take quite a bit longer than the time it takes to do the actual job, but it would still be time well spent.
All the best, Stan
Davis SC
02-16-2008 21:35:51
I just hire a roofer,, As fat & clumsy as I am... I realize that roofers work much cheaper than Paramedics, ER Docs, & Orthapaedic Surgeons..
jose bagge
02-16-2008 21:16:39
Winds sure have been crazy in Va this week. Had to rehang the vinyl ceiling under my porch today...lost 2 shutters completely and lord knows how many shingles!
NE IA
02-16-2008 20:12:20
Two ladders with a rope or chain and tie the ends together. Throw one end over each edge of the roof. Chain or rope the very top rung of each ladder. No you will not be able to pull the other ladder over the roof unless it has very little pitch. Keep it low to the roof and try to pull it over if you are concerned. The ladder over the other edge will top out and stop. One time in the last thirty five years we had a wind blow both ladders (alumn)off the roof during the week end. Another idea is these ratchet tie downs you can buy for about six dollars. They work like a pulley that you pull the rope over and then just let go. We have used them on real long roofs to tie off yourself to a ladder that is over the roof. The rope that comes on them is probably six foot. You just buy a 3/8" rope and replace the short one. Total investment is less than ten - fifteen dollars.
I don't know how much experiance you have with this so I will suggest. Just a word of advise, use tar in a calk gun to seal down the replaced shingles, and while you are up there, migh as well do the ones that are not sealed down good because you will no doubt be replacing them another time. You do not need very much, if you use to much your shingle will buckle sometimes.
Lee in Iowa
02-16-2008 17:08:38
You can buy hooks that go on the end of your ladder and hook over the ridge. Lee
Ray(MO)
02-16-2008 17:00:39
Foam cushions off an old chair or sofa or foam carpet pad work good on asphalt and tin roofs. Golf shoes left to many holes.
Bob Huntress
02-16-2008 16:49:01
Something along this line...
