Tool Talk Discussion Forum
Air Compressor
Illinois
02-16-2008 12:51:09
If an air compressor is rated at a 10 CFM at 90 PSI, what does that mean?
Does that mean that it would put out an amount of air equal to 10 cubic feet pressurized at 90 PSI?
Or, does it mean that it would put out an amount of air equal to 10 cubic feet of air at atmospheric pressure, only pressurized to 90 PSI?
If I would connect that compressor to a 10 cubic foot tank, could it pressurize it to 90 PSI in a minute?
Gun guru
02-16-2008 15:29:29
 Re: Air Compressor in reply to Illinois, 02-16-2008 12:51:09
The best way to think of it is that the compressor is rated 10CFM and 90Psi. That means that the compressor will Maintain a continuous 90Psi with 10CFM of air flow. An air compressor will deliver about 3.6 cfm per input horsepower at 100psi so the compressor you are looking at is about 3-4HP. If a compressor says it will deliver 30CFM at 100 psi and the compressor is 5HP then you know that they are lying. Rotary screw compressors deliver as much as 4.3cfm/hp but are alot more money..... Us shop guys use piston compressors.
Rod (NH)
02-16-2008 14:51:06
It means that at a discharge pressure of 90 psig, the compressor is delivering 10 cfm of ambient air, sometimes referred to as "free air", the volume being referenced to the ambient temperature and barometric pressure.
No.
Yes.
No. About 60 cf of atmospheric air would be required to be added to a 10 cf tank starting at atmospheric pressure in order to pressurize it to 90 psig, neglecting temperature differences. Therefore about 6 minutes would be required. This is approximate since temperature is neglected and the average cfm between 0 and 90 psig is a little greater than 10 for a compressor rated at 10 cfm@90 psig.
Slowpoke
02-24-2008 23:03:24
 Re: Air Compressor in reply to Rod (NH), 02-16-2008 14:51:06
Is that the same as saying the compressor pulls in 10 cu ft per minute and discharges it at 90psi in a much smaller volume?
xstaticdrummer
02-16-2008 14:13:08
It means that it will pump 10 cubic feet per minute of air at 90 psi. So if you have an air tool that requires 7 CFM at 80 psi this compressor is big enough to run the tool
