Have a question in regards to straightening a fence I installed last summer, this is a 4"x4" post with 6x8 stockade type panels. One leg is 70 feet, to the corner, the other is 100 feet to the corner, the middle of this 100' section has bent over out of plumb. I used 10 foot posts and buried them as deep as I could dig by hand, the middle of the 100 foot span is where the problem is, and the grade changes slightly, middle is lower than both ends, I did re grade the site but just scraped the surface and filled low areas to make it as level as possible, the soil around posts is for the most part undisturbed. I think it's also heavy clay type soil. Thet are set at least 3 feet deep each 8 on center, the 70 foot leg is anchored to a concrete wall at one end, so is the 100 foot section, 70 foot section I did concrete a few holes as the shale rock slope up to the surface along that run, also chopped out a socket in the shale and placed concrete, this side is good, the other side just went out of plumb after the frost and thaw cycle, the post holes are wallowed out, possibly the wind pushing on the fence, and soft ground. I'd like to straighten this thing out, it's a customer of mine and I told her I'd be back to set it straight when the ground thaws, most fence outfits do not concrete or use dry mix, as they state the posts decay sooner, so I set and packed these in tight, really spent a lot of time on this job to do it right, beyond what you would get from a fence contractor, using those end brackets, chopping out in the shale etc., the ends of each run are anchored and set with concrete, I was on the money, dead on the property line with an 1" to spare in my favor, now it's an embarassment to look at ! LOL ! Well she knows I back my work, no problem at all, heck she never even called, I went back and looked to see how it held up, what I saw was a little different than when I installed it. What I'm wondering, after re-plumbing the 100 foot run, I can anchor to the building and pull it back, it's brick, open the hole make room pull some more, then brace etc., should I just concrete a few posts in the middle, frost may heave up but the out of plumb thing with this heavy clay soil seems to be worse of a problem. Seems the middle post on this run may have the shallow'est post depth and is weakest one, just wondering what might be the best fix, not a fence contractor, but will do them at a customers request. One photo of the site, day 1 on the job.
Posts set on 100'-0" run
