Tool Talk Discussion Forum
Very off topic--I'm gona ask anyway
ldj
02-15-2008 17:33:36
I know this is wayyyy off topic of tools. I have saw a lot of OT things here and seems no one minds and everyone tries to help and I have enjoyed and learned a lot from those OT posts. Here Goes----- -----
I bought a set of 318 Chrysler heads and intake manifold from a marine engine wanting to use for automotive use. Got them home and looking them over good. The heads are the same as automotive. That intake manifold is different. Where the water inters from the right head into the manifold and on to the thermostat housing, well in that passage it is blocked real close to the thermostat housing. This was built this way, you can tell by the casting. On the top of that passage about where the heater hose would go there is a very large 1" pipe threaded hole. With that large hole, and that passage blocked, I can assume it was designed for the water to exit there and go directly to the water pump. Why would it not go on into the thermostat and then into the radiator like automotive?
Should I use this manifold or not and how would I deal with that water flow?
I have looked everywhere on the internet I can think of and no answer. So maybe here someone will know or can tell me of a group that may. I can post or e-mail personally a photo to someone if it may help. Being this off topic I hesitated posting photo
L.D.
Bob Huntress
02-16-2008 17:08:41
 Re: Very off topic--I'm gona ask anyway in reply to ldj, 02-15-2008 17:33:36
I would not recommend using a manifold designed for marine use in an automotive application. Not knowing who manufactured your marine head, we don't even know how thick the walls are, or whether there is good air distribution within the manifold. The 318 is often used as an inboard marine engine. In most cases it has a closed cooling system that cools the primary coolant with raw water in a heat exchanger located in the expansion tank. This means that you are not likely to have any salt in your manifold, which is a good thing, as salt would have corroded the entire water jacket. I would, however, verify that there is no salt in the head, though.
chas
02-16-2008 03:22:50
Supporting what Goose says, many marine applications use a dual cooling system with engine coolant circulating in a closed system entirely seperate from the "raw water" system which "cools the coolant" via a heat exchanger then exits via the exhaust system, cooling and quietening that. I would recommend using manifolds specific to the application, automotive or marinised as appropriate..... Chas.
rubberwrench
02-16-2008 02:46:05
some of those manifolds used GM carbs
old bc
02-15-2008 20:53:03
Chrysler marine raw water cooled thermostats are designed to circulate water continuously through the pump so that the rubber impellers won't be destroyed.
old_bc
Goose
02-15-2008 18:28:39
Should have mentioned, there is no radiator used.
Goose
02-15-2008 18:02:35
A marine application would have water-cooled exhaust manifolds. In other words, the cooling water is rerouted to exit through the exhaust manifolds for the obvious purpose of keeping things cooler under the hood on a boat.
It's not a closed system like on a car or pickup. Basically, cooling water runs in a continuous flow from a pickup grate under the hull, through the engine, and then is routed into the exhaust manifolds to exit out the exhaust pipes.
Actual piping could change from boat manufacturer to manufacturer and from one application to another.
Some racing boats have a closed system with a radiator, but most pleasure craft have the open system with water cooled exhaust.
