Tool Talk Discussion Forum
Update, additional info
Tim B from MA
02-15-2008 06:38:50
Thanks to all for convincing me is it important to do a bit more work to get the right equipment.
I found new-old-stock (sort of) replacements on the internet and bought 4 for the price of one new one from my welding supply store (I'd bet I get them sooner too).
This fuse has a paper cartridge so fire prevention or physical saftey does not seem to be an issue.
I also found info sheets on these fuses (Bussman NOS) on the Cooper-Bussman web site. Based on my read, there really does not seem to be anything special about this fuse, except it's physical size. Perhaps that is just to prevent arching across the fuse block when it blows ???
Anyhow, thanks again.
Tim
Bob
02-15-2008 06:58:59
 Re: Update, additional info in reply to Tim B from MA, 02-15-2008 06:38:50
Even if the outside is paper, you will find it packed full of a fire/arc retardant powder. (I USED to know what they used!)
ANYHOW, it's the LENGTH that helps to keep a destructive arc from occuring when the fuse blows.
Some more modern 600 V. fues are shorter, I'd 'spect they have a more "high tech" arc suppression material in them to compensate.
Tim B from MA
02-17-2008 18:58:09
 Re: Update, additional info in reply to Bob, 02-15-2008 06:58:59
Yes Bob I opened up the old one, and saw the powder.
The element was broken but to me it looked like it corroded (some oxidation evident on the copper element) rather than melted (Of course I can't tell for sure), so I'm hoping it did not blow.
Of course I if that is the case, I would also wonder what else has corroded in the machine.
36 coupe
02-17-2008 14:57:56
These 5 inch fuses are not uncommon ,I found a box of 30 amp Royal NO ARK on the shelf.Theres a 3 fuse block with some 3 and 2/10 amp dual element fuses in it.I expect they were used in 440 v circuits.
Tim B from MA
02-15-2008 06:50:45
 sorry -one more thing in reply to Tim B from MA, 02-15-2008 06:38:50
I'm not sure the fuse is actually blown - it may be physically damaged/worn out. The copper/brass contacts are loose on the carboard cartridge and when you twist them one way you get some continuity and the other you get an none. After I get my replacements, I'll cut it open and have a look.
This welder seems to have sat in a humid basement for a long time so the cardboard cartridge may have been comprimised by moisture.
I took a chance on the machine for $100.
