Be careful. I would suggest following the manufacturer's recommendations. It might save you a whole lot of hassle later. Admittedly it was about 30 years ago, but I got the bright idea to change the oil in my transmission and rear end in my Duster to synthetic from 90W gear lube. The car sat out all the time, and sometimes I would have to drive it for a mile or more before I could get it to shift out of low. I bought the Amsoil gear lube from a local dealer for about $50 to$60, and they said I would love how it worked. It did make the transmission shift much easier when it was cold, and probably did increase my gas mileage a small amount. However, within a year, both the transmission and rear end started making unhealthy sounding noises. I ended up needing to put all new bearings in the transmission. The rear end was too far gone to fix, with wear on the bearings and ring and pinion. I just replaced the whole rear end with one from a wrecking yard. Both got new regular gear lube, and both are still in that old Duster. Now maybe the synthetic lubes have improved since then, but it would be very hard to convince me to use them unless the manufacturer says they would be OK for that application. Good luck!
