Tool Talk Discussion Forum
Webster Honing Machine
oly1212
02-10-2008 15:47:47
Looking for info on a Webster Hone I saw an old post about using an adapter i was woundering if that worked.
dr sportster
02-11-2008 05:49:55
 Re: Webster Honing Machine in reply to oly1212, 02-10-2008 15:47:47
That was my post.I never got the adapter or even found out if one was made.I did drill out one of the ends of an arbor and adapted a Snap-on engine hone to it with an oil hole for honing oil.The diameter adjustment is on the Snap -on hone and the dial on the unit not used.Since the cylinder must be worked by hand I made big pieces of aluminum flat stock to bolt it to and the placed rails on each side of the Webster for them to ride on.It does make a very round hole but its still a workout.This includes the cylinder being hung on bungee cords to releive your arm muscles.I looked on ebay for about a year for tooling without any luck.Once you place the Snap-on[or Lisle,whatever brand] the foot pedal should have a saftey switch because if a cylinder is not on the hone it can come around and smash the stone and the foot pedal on the floor is hazardous.I only have one diameter original Webster stone arbor and upgraded the motor a bit for the larger diameter cylinders.Im talking motorcycle jugs not engine blocks.but it works.[You must rotate the cylinder occasionaly in its "slider plate" to ensure a perfectly round hole[gravity?].I have found no info on these machines on the web so Ive just worked with what Ive got and not really doing any Sunnen hone type jobs as I hoped when I bought it.Good luck with yours and let me know how you make out.I did not contact Sunnen or Superior hone companies by telephone about the adapters just checked on websites.Use real hone oil.[Atlas.Goodson]
george md
02-11-2008 12:21:55
 Re: Webster Honing Machine in reply to dr sportster, 02-11-2008 05:49:55
dr,
I'm the guy that told you superior made an adapter for webster machines. I called them today and they will call me tomorrow as to whether they make that adapter any longer. I will let you know.
george
dr sportster
02-12-2008 11:33:04
 Re: Webster Honing Machine in reply to george md, 02-11-2008 12:21:55
Thanks George.
oly1212
02-12-2008 18:23:01
 Re: Webster Honing Machine in reply to dr sportster, 02-12-2008 11:33:04
Thanks George & Dr I am going to send a hone arbor to Sup Or now Tenn Abrasives. I am an antique motorcycle restorer teens Indians and Excelsiors. Oly1212
george md
02-12-2008 19:17:37
 Re: Webster Honing Machine in reply to oly1212, 02-12-2008 18:23:01
Oly,
The part # for superior hone for the adapter is W-2000 . I have an old catalog with the part #'s . I was gone today ,so I didn't get the call as to whether they have the adapter anylonger.
They are in Sarasota , fla
phone # 1-800-237-2328
george
oly1212
02-13-2008 18:57:19
 Re: Webster Honing Machine in reply to george md, 02-12-2008 19:17:37
Thanks George I will call in morning I found an original operating manual an if any one needs a copy let me know.
Oly1212
