Tool Talk Discussion Forum
anyone ever tried this?
Oldcraneguy
02-10-2008 12:27:16
Over the years Ive run across several power tools that I wish ran slower, my detail sander comes to mind as well as a small lathe Ive got..I was just thinking about wiring up an outlet box with a supply cord and putting a light dimmer switch in it, Im pretty sure it would work but Im wondering what the long term affects would be on the motors I power with it? Anyone ever tried it?.....Don
dr sportster
02-11-2008 06:03:27
 Re: anyone ever tried this? in reply to Oldcraneguy, 02-10-2008 12:27:16
Yes 1000 watt with cooling fins lighting dimmer on band saw.Saw lost power and dimmer was removed.I concluded dimmers are for lighting and motor controls are expensive.I still have to slow the saw down with pulleys one of these days.
IH2444
02-11-2008 05:37:30
If the dimmer can carry the current demands of the tool and the motor is AC/DC type (has brushes) should be fine. It is the same method of controlling the speed that the manufacturers build into the variable speed drills and such.
Bendee
02-10-2008 16:28:35
can buy a powerpoint with variable speed wheel, but told it will ,in time, burn out the tool.AC 240 volts here.
Bendee
02-10-2008 16:27:48
Gerald J.
02-10-2008 14:56:07
Depends on the motor. If AC/DC with brushes, the dimmer will work beautifully. That's how variable speed drills work, with the dimmer circuit in the trigger/switch.
With the induction motor that has a starting switch that kicks out the start winding at a certain speed, you can't do that well. Unless its specially made for that like some vintage fans (floor and ceiling).
The induction motor speed is set more by frequency than voltage. You can go to a variable frequency drive and a three phase motor, but changing the motor pulley is a far less expensive technique.
Gerald J.
james Coombs
02-10-2008 14:41:26
any ac motor that is designed to run at a certain speed will eventually burn up if run at a higher or lower voltage , the only remedy is to change the cycle . us power runs at 60 . example a 380 volt 50 cycle 3 phase will run on 440v 60 cycle
Chuck (CA)
02-10-2008 13:19:43
You might look for and old sewing machine speed control; the kind you use with your foot. They have a receptacle for the motor to plug into and the pressure of your foot controls the speed... hands free....
I"ve used one for a dremel tool and was very handy.
Chuck
Oldcraneguy
02-10-2008 13:32:11
 Re: anyone ever tried this? in reply to Chuck (CA), 02-10-2008 13:19:43
I was just talkin to my wife about what I was thinking about doing as far as a speed control and she said "why dont you just use the foot pedal off that old sewing machine, your never gonna redo the cabinet" and turned around and walked out..lol
Sheesh I Coulda Had A V8!...thanx all for your imput
kidbob
02-10-2008 13:17:07
The common cheap speed controls work on AC/DC or DC motors, just use a big enough control for the motor you want to run.
AC only motors require frequency control, which is not as cheap or common to find.
s.crum
02-10-2008 13:03:21
Check on Fleabay there's usually several types of motor speed controls, generally rheostat type boxes. Don't know if a standard light dimmer would be heavy enough to handle a motor load. I've used rheostat boxes on milwaukee grinders and buffers for years. The one's I've used are Dayton brand and are for this purpose.
Bob Huntress
02-10-2008 12:47:23
In the case of your lathe, have you considered simply changing the driven pully?
JMS/.MN
02-10-2008 12:33:28
Tend to burn up. DC motors can vary speed with a variable rheostat when operating on DC current. Don"t know about motors marked AC/DC.
Greg_Ky
02-10-2008 12:31:56
I have done this for years with an electric die grinder (Makita) that is now around eighteen years old. (no ill effects on the tool)
