Tool Talk Discussion Forum
Cruddy fuel tank on Reddy Heater
ramtuff
02-09-2008 20:59:07
Have a 150. 000 btu Reddy Heater,it's been sitting around for 4 or 5 years with diesel in it.I finally got the fuel burned,by cleaning the suction screen about 50 times.The bottom of the tank has a lot of crud in it.Don't think its rust?What would be the best way to clean it out? Thanks;
ben brown
02-10-2008 07:06:16
 Re: Cruddy fuel tank on Reddy Heater in reply to ramtuff, 02-09-2008 20:59:07
i had the same problem removed the screen and then where the line comes out of the tank out side installed a in line fuel filter clear one so you can see when it plugs up take it off blow back through it then reinstall . i also took the fuel cap off then sit there and sloshed the fuel around, with a short pices of clear plastis line and sucked up the crud took some time but beats buying a new one
