My last posting was regarding metal cutting band saws. In reading the responses, it occurred to me that y'all may have some useful ideas for my next project.My next project is a set of louvers for the fenders of my pickup. I want to get heat out of the engine compartment. I have a '75 Dodge truck, and at the back of the fenders is a perfect place to install vents. I plan to cut the existing sheet metal of the fender in squared-off C-shapes to form the louvers. They'll be rather shark-gill shaped inward louvers, aimed to get the heat out. Then I will clamp the fender sheet metal between sorta-sawtooth shaped 3/8" mild steel stock. Hard to describe, but easy to draw. I'll screw the two pieces of stock together from the back-side with 1/4-20 screws and locktite through the sheet metal. Alternately, I will make louver assemblies in the shop. I'll slot the bar/plate stock and insert/screw individual louvers into the slots. Then, I'll just cut square holes in the fenders and screw the assemblies to the fender from the backside. Probably the easier approach, but I'm not sure it would look as nice. Probably would allow for more heat exit with these simpler louvers. This is actually a practice run for putting similar louvers on my custom New Yorker. I've got a wicked vapor-lock problem on it. So, I am looking to reduce the under-hood temps. I have a high-tech ceramic coating on the manifolds to keep the heat down. I have a good electric pump at the tank. Those helped a lot. Hot starts are always a problem. I have actually seen hot gasoline fountain out of the carb when the gas in the carb boiled. I have a heat spacer under the carb. Heat cross-over is blocked-off. I have a valley pan under the manifold. So, I'm trying other stuff. Even if this project doesn't help, it will look cool.
