Stuck jd 520 clutch assembly
russ lante
08-09-2001 20:09:44
hello,
I was wondering if you have any ideas or trade secrets for taking off a stuck clutch plate assembly for a JD 520 circa 1958. It has a hand activated clutch. The disks and plates are located inside the belt pulley assembly. The initial clutch disk comes out fine. The stuck part is the large assembly just after the first (or outermost clutch disk). It is mounted on a splined shaft and has two tapped holes for use with 7/16 bolts and a gear puller. I tried the bolt on gear puller illustrated in the repair manuals and it refuses to budge. I put enough pressure on the tapped bolt holes to partially strip the threads out of one so it had to be tapped deeper. then I tried a small 3 arm gear puller, liquid wrench, and a bit of heat and light tapping with a small hammer hoping it would loosen it. I have been applying more spray on penetrating oil (liquid wrench like stuff) daily and will try the bolt on puller again if noone has any other suggestions.
I like this tractor alot and prefer to do this work myself. Every time I bring it to the john deere shop nearby, they use it as a training tractor for their new help and it comes back in worse condition than it left.
I still need to rebuid the power steering pump from the local john deere shops last 3 attempts to fix it.
So...any advice, suggestions, and help about power steering pump rebuilding and how to remove this clutch assembly to replace the inside disk from the tractor restoration experts like you would be greatly appreciated. Thank you for your time and i look forward to hearing from you.
Sincerely,
russ lante [email protected]
GPWT
08-10-2001 09:51:06
 Re: stuck jd 520 clutch assembly in reply to russ lante, 08-09-2001 20:09:44
I have found that some of these clutch drive discs need considerable heat input to loosen them. Apply the heat at the same time the puller is exerting tension, add the heat as quickly as possible. Hot and fast is the rule here, it minimizes the amount of heat transfered up the crankshaft. If you get the disc off, it is wise to remove the belt pulley to clean and lube the pilot bearings. Also, put never-seeze(sp?)on the crank splines when reinstalling the disc.
