Tool Talk Discussion Forum
Rusted Manifold Nuts
doorman
02-08-2008 22:09:44
When I removed the manifold on my WD45 two of the nuts were rusted solid. I was afraid of breaking the studs, so I used my Dremel tool with a cutoff wheel and sliced them as deep as I could, then I split them with a chisel and then "chased the threads". Hope this tip will help someone in a similar situation. doorman
2x4
02-09-2008 20:36:41
 Re: Rusted Manifold Nuts in reply to doorman, 02-08-2008 22:09:44
torch works really good too. Heat the nut red hot, then turn the nut. It will squeek & scream all the way, but it will come off.
Oakley-2
02-09-2008 04:51:53
Thanks for the tip doorman, could use that alot sometimes. 36 coupe puts on brass nut after he uses your tip.
36 coupe
02-09-2008 03:06:22
Brass nuts should be used on manifolds.
