Tool Talk Discussion Forum
Pump for filling tire with Methenal
Bill in Colo
02-08-2008 08:59:33
I have a tractor that doesn't have enougth methenal to keep tires from freezing,need to know what kind of pump to buy,and can I add by only taking out some fluid and increasing the consentration. Don't want to use cacl as these are tubeless. I know I should have used iron. Suggestions needed.
unioncreek
02-09-2008 08:35:40
 Re: Pump for filling tire with Methenal in reply to Bill in Colo, 02-08-2008 08:59:33
I he"s using methanol I wouldn"t want to be anywhere close to those tires. Methanol has burn point (don"t know the correct term) of around 150*"s, those tires will reach that just setting out in the sun.
Bobg
Bob
02-09-2008 08:41:36
 Re: Pump for filling tire with Methenal in reply to unioncreek, 02-09-2008 08:35:40
I ASSUME, they are talking about winshield washer fluid, diluted methenal???
gary tomaszewski
02-09-2008 07:18:38
Only curious, are you using Methanol? You do know that methanol is corrosive, and will eat metal especially the brass in the valve?
TominKy
02-09-2008 13:32:16
 Re: Pump for filling tire with Methenal in reply to gary tomaszewski, 02-09-2008 07:18:38
I know personly a tire dealer who uses methanol, or methyl alchohol as its also known, straight from the drum to ballast his tires.
Bill in Colo
02-08-2008 17:11:19
Thanks guys for the suggestions. I think I'll do the gravity method. I would use T_Bone's vaccum idea, but my vaccum pump is a one mile uphill hike in three + feet of snow and I don't have a snow machine.
135 Fan
02-08-2008 13:18:21
Maybe an air operated engine cleaning gun could be used? It uses the air to suction varsol or other liquids out of pails. Like T_Bone said, suction may be better than using pressure. If you don't need to add a lot, maybe a suction gun that is similar looking to a grease gun could be used? I use a big syringe with a length of small hose on it to take oil samples out of the dipstick hole on equipment. All of these are rather inexpensive. Dave
old
02-08-2008 13:12:34
Send me an e-mail and I'll send you a page from a 1935 JD-B owners manual that will show you a few ways to do just what you want to do and theres a couple of them that you don't eve need a pump to do it
Jerry/MT
02-08-2008 11:35:48
You don"t really need a pump. You can let gravity do it. Take a five gallon plastic bucket and put a fitting near the bottom that has a barbed end to put a hose on. Gempler"s sells a special valve for about $12 that lets the fluid in and the air out. Put he bucket on a ladder above the tire stem, attach the tube to the tire sstem and fill the bucket with fluid and go have a cup of coffee. The fluid will drain into the tire and you keep adding fluid till you get the tire filled to where you want it.
A guy name of old, who posts quite often, has written this method up and if you holler for him, he can give you some more specific info.
Ted Seifert
02-08-2008 11:26:32
Use a barrel , drill a hole in the bung and put a tube through it long enough to reach the bottom of the barrel . Braze the tube to the bung plug. Connect a small rubber tube (air hose) to the tubing from the barrel. adapt the end of the hose to a small piece of tubing that will fit through the valve stem. The other bung plug could have a short pirce of tubing through so that you can apply air pressure. DO NOT OVER PRESSURE BARREL 5-10 psi is all that is needes. This way no pump is required.
T_Bone
02-08-2008 10:31:20
Hi Bill,
I would reverse my thinking and use a vaccum. A standard vaccum will pull about 20"hg and then just let the fluid be drawn in.
T_Bone
Bob
02-08-2008 16:01:21
 Re: Pump for filling tire with Methenal in reply to T_Bone, 02-08-2008 10:31:20
If he's REALLY using methanol, and takes your vacuum suggestion, he may be in for a flaming surprise!
T_Bone
02-08-2008 17:01:01
 Re: Pump for filling tire with Methenal in reply to Bob, 02-08-2008 16:01:21
Hi Bob,
The Darwin award for Stupidity usually elimnates the severe mentaly challanged as your article suggests. Anyone that would run a flamable liquid/vapor thru a electric motor would surely fit into this class.
You pull a vacuum inside the tire then remove the vacuum pump source THEN the liquid is drawn into the tire via negitive pressure.
A vacuum cleaner used as a vacuum pump only creates the negitive pressure and is never in contact with the flamable medium.
Thanks for the heads up for the ones that can't/won't think for themselfs. :)
T_Bone
jonjon
02-08-2008 10:18:58
I use a 7 roller pto pump that dad uses for spray applications. Just run some oil through it when your finished. Dont see a problem with increasing the concentration as to much is better than not enough.
