Tool Talk Discussion Forum
Ford v8 intake leak
john908
02-07-2008 19:15:13
2000 Ford V8 intake manifold leaking coolant seem's common.Has anyone repaired one of these?Is it just replace the intake gasket?
IH2444
02-08-2008 08:55:06
 Re: Ford v8 intake leak in reply to john908, 02-07-2008 19:15:13
Not familiar with the 5.4 but a 93 lincoln 4.6 has a coolant hose under the intake that leaks and requires removal of the intake to repair.
Does your engine have the elevated intake with open front and rear ?
azharry
02-07-2008 20:12:14
It depends on which engine you"re talking about. Crown Victorias had a problem with the crossover pipe cracking causing the intake itself to leak.
john908
02-08-2008 03:46:16
 Re: Ford v8 intake leak in reply to azharry, 02-07-2008 20:12:14
The 5.4 in a Econoline
