Tool Talk Discussion Forum
log splitter
welchpj
02-05-2008 18:57:09
Thinking of purchasing a 22 ton log splitter. Any issue with this size? The cost will be $900.00 plus tax. Any comments?
Chuck (CA)
02-07-2008 19:34:54
 Re: log splitter in reply to welchpj, 02-05-2008 18:57:09
I'm not a big fan of MTD, but I have one that has a 25 ton rating. I burn a LOT of almond, which is common in this part of California (Central Valley) and it is a very gnarly wood. I've had it about ten years and it has never failed to split a log. It can go either vertical or horizontal and I've used it both ways. I would like to see it about 10 inches lower in the horizontal position, (I'm 60 Yrs old and the wood seems to be getting heavier each year), but as far as I'm concerned, it's the only way to go.
Chuck
Tim B from MA
02-07-2008 09:03:17
No. 1 recommendation - get a splitter that has the wedge on the piston, and the stop at the end of the beam. That way, the wood stays in one place and you don't have to retrieve the wood from the grond every time you want to re-split a billet into a smaller diameter.
It is hard to find a factory made horizontal machine that is set up like that - all vertical/horizontal combos are set up that way.
I can't say whether I'd recommend a vertical/horizontal - never used one BUT .... I'd hate to have to bend over every time I need to touch the wood (vertical), and (for most iI've seen) in horizontal position it looks like the wheel is in the way and the beam is too high off the ground.
Proper height for a horizontal beam is just above your knee so you don't need to bend over to hold the small logs and can "catch" the close half of big logs on your thigh after the split.
NE IA
02-06-2008 16:05:54
I'v had one since 77 and no money could buy it from me. I'v had alot of maul folks rent mine over the years.
One thing that I have noticed with two different horizonal / vertical models is that when in the horizonal position you have to lean over the wheel. Just not enough room for my big feet, and it is important to me because alot of time is spent splitting sometimes.
I did add a hydrolic lift pan to mine that makes it so much less work lifting the big ones. A lift pan can make a nice place to have someone get ahead placing then on deck.
Chad Franke
02-06-2008 13:33:06
Who's splitter are you looking at? Company I work for makes a "few" every year. I think it was around 40,000 last year. I know a bit about them. :-)
El Toro
02-06-2008 13:18:47
third party image
Let me try that splitter again. Hal
El Toro
02-06-2008 13:16:45
If you're handy with metal you can build it yourself. I built this in 1982. I had the 10hp Sears Tecumseh engine. I used a 4 inch I-beam if I was doing it again I would use a 6-inch I-beam.
I bought the 2-stage pump, control valve from Northern Hydraulics in MN. I bought a steering cylinder at a government auction with a 3-inch bore. I had to cut the shaft since it was too long. I got the hydraulic hoses from where I worked. I bought the wheels, tires and hitch from a boat yard. Never had to run the engine more than 1/3 throttle. Hal
third party image
third party image
cj3b_jeep
02-06-2008 08:08:22
That seems like a good price if it's new. Make sure it has a name brand engine, not some chinese look-a-like. Honda engines seem to always start well. Also make sure the main beam is heavy enough. Just because it has 22 tons of force at the ram does not mean the beam can handle it. Spliters that go vertical are easier to use and when horizontal are usually higher so you don't have to bend over. I have a log spliter that belonged to my father in law. I use it all the time and it works great. We split about 3-5 cords a year for ourselves and my brother in law.
Bob
02-05-2008 21:49:59
You sure are giving us a lot to "go on" as to what make and model you are looking at!
tractormarkb
02-06-2008 06:54:18
 Re: log splitter in reply to Bob, 02-05-2008 21:49:59
No one needs a Hydralic Log Splitter. Just something else to Maintain and keep from thiefs. A good Maul does wonders for splitting and exercise. I keep a pile of logs I am unable to split and use them for camp fires and rent a Splitter one day a year to split the nuckles. Let the Rental place take care or the Maintenance.
El Toro
02-06-2008 18:35:21
 Re: log splitter in reply to tractormarkb, 02-06-2008 06:54:18
I bet you don't use an old crosscut saw with maul. Hal
BENJAMIN KIMM
02-06-2008 07:12:23
There i must dissagree with you....our farm splits over 22 cords a year to feed our heating system...it heats two houses and pre heats the hot water system in both, and will soon heat the floor heat in our shop. Theres no way we could split that much white oak and poplar without our log splitter...and forget the local rental shop... between the faulty equipmet and poormatinience by part of the staff (I used to work there, oil didnt get changed one one of our skidsteers for over 1300 hours! and i got chewed on when I went to change it)plus wehat it would cost us in the long run to spilt wood for several weeks. just my couple pennies
IH2444
02-06-2008 08:01:33
 Re: log splitter in reply to BENJAMIN KIMM, 02-06-2008 07:12:23
Then there are those of us with physical imitations on using a Maul. I love my log splitter. With a bad back the vertical ones are even better.
