Tool Talk Discussion Forum
What is SPL horsepower for an electric motor?
Pat Brock
02-04-2008 18:44:41
This message is a reply to an archived post by Brad on May 23, 2004 at 08:37:33.
The original subject was "What is SPL horsepower for an electric motor?".
What is the actual horsepower for a pump motor rated 5.0 SPL?
ChrisB
02-19-2008 10:48:37
 Re: What is SPL horsepower for an electric motor? in reply to Pat Brock, 02-04-2008 18:44:41
Best marketing BS is the "maximum developed HP" spread by Sears.
I love the shop vac that they claim develops a maximum of 18hp. All from a 110 outlet.
I stopped buying power tools from Sears after they started this crap.
Worse yet look at the floor models of some of the larger power tools on display at Sears. Drill press for example. They actually take the HP rating plate off the motor for the display models.
JMS/.MN
02-05-2008 12:13:03
Watts equals amps times volts. Check the numbers (amp draw and voltage) on the nameplate, do the math, divide by 745 (745 watts equals one hp) to get true hp. Air compressor motors are notoriously overrated. Advertising gimmick.
buickanddeere
02-06-2008 06:10:32
 Re: What is SPL horsepower for an electric motor? in reply to JMS/.MN, 02-05-2008 12:13:03
Ac Watts = volts X Amps X power factor. HP = V X A X P.F. X % efficiency.
IH2444
02-05-2008 07:09:16
I believe that is the stall HP. Ie when the motor stalls out and starts to smoke ;)
Dusty MI
02-05-2008 05:37:18
True HP is the amount of HP @ full continuous running. The other HP is just befor the motor stalls.
Bob
02-04-2008 20:02:02
It means "SPECIAL", and if it is an air compressor, that is a sort of "license" for the MFG to screw the public.
Jon Hagen
02-04-2008 20:13:53
 Re: What is SPL horsepower for an electric motor? in reply to Bob, 02-04-2008 20:02:02
Kind of like the "magic" 6.5 HP compressor motor I bought from TSC a month ago. It draws 21 FL amps at 230 volts,which = an honest 3-4 HP ?
steveormary
02-06-2008 03:21:21
 Re: What is SPL horsepower for an electric motor? in reply to Jon Hagen, 02-04-2008 20:13:53
I never could figure that out either. I am retired now and I am sure we covered that in our code classes. And I too think it is a ripoff.
steveormary
0x00
02-18-2008 20:06:27
 Re: What is SPL horsepower for an electric motor? in reply to steveormary, 02-06-2008 03:21:21
21 FLA at 230V is probably a TRUE 5HP motor. that is about 6.5 from the wall and PF and %eff probably reduce the 6.5 down to 5 shaft horsepower.
I looked at a cheap motor online today rated 5 spl and when i did the math it was 3.7hp shaft.
it it is pulling 5HP from the wall (even assuming PF=1 and eff=1) it is certainly NOT delivering 5HP out the shaft.
