Rust removal
Don
08-08-2001 18:46:42
I am sure this has been covered before but here goes. I have a trailer that needs painting. What is the best way to get the rust off? Is there some chemical that I can spray on and wash off (that would be nice).With A scratch wheel on a grinder I can get the outside but not the inside of the frame nor in the corners. Thanks for any advice, Don
KEG
08-12-2001 19:19:42
 Re: rust removal in reply to Don, 08-08-2001 18:46:42
Once you get pass the loose rust, I have had luck using aluminum paint as a primer (or even a finish coat). I have some old equipment that I painted aluminum paint over the rust and it has lasted for fifteen years.
KEG
MarkB
08-09-2001 17:01:41
Commercial fishermen swear by Ospho. Get it at paint stores or marine hardware stores. One source is Jamestown Distributors; see link below.
Ray,IN
08-08-2001 19:50:01
 Re: Re: rust removal in reply to Mark Kw, 08-08-2001 19:36:54
Naval Jelly will work to remove rust. Sandblasting is the best, if you've got the equipment; expensive if you don't.
