Hi Tim, I think I can help you with the burning through at the edge problem---don't use 5/16" electrodes. Since they won't even strike an arc at less than about 350 amps, of course they're going to burn through metal that's just over 3/16" thick. And since they're about the size of Little League bats, they're hard to control without using a tripod. Okay, just kidding; I know a typo when I see one. But if either the numerator or denominator you gave is correct, you may be using rod that requires too much power for the job you're doing. 3/16 and 5/32 are both bigger than I'd use (I discount the possibility that you're using 1/16 and accidentally called it 5/16---for one thing, it wouldn't burn a notch on the edge of 6 gauge without you really working at it.) With metal .2031 thick, you should have good luck with 3/32 or 1/8 6013, 6010, 7014, or 7018. 6010 (6011 if your welder is AC only) is an extremely effective electrode that welds better than it looks like it's welding. Compared to the medium penetration, heavy flux electrodes like 6013 and 7014, 6010/6011 always seem to be on the verge of being out of control. The powerful arc, the spatter, and the heavy smoke make you think you're burning up the work, but the deep penetration and quick freezing can make them outperform the gentler electrodes---even on thin metal. 6013 is a pleasant rod to weld with. It strikes and restrikes easily with either AC or DC. You can run it so that the slag lifts itself off as it cools. You can get a weld bead that's so beautiful that you want to take a picture of it and frame it. The only problem is that it doesn't like dirt, or grease, or rust, or poor fit up, or cold metal. And sometimes, it lays down what looks like a perfectly good bead, but when you chip away the slag there are areas that look exactly like two half size beads, side by side, with a space (filled with crispy slag) between them. I've tried ten brands of 6013, every size from 1/16 to 1/4 (Peewee League bat), and more hours than I want to think about, trying to find out why that happens. I've run hot, cold, fast, slow, near, far, and always, it sometimes just happens. If 6013 didn't also happen to be particularly good at creating a texture I use for a lot of a certain kind of sculpture, I would have stopped liking it a long time ago. Be careful with the knob on the back of the headband---the splines on the tightening mechanism strip out pretty easily. And if you get your hands on a wire feed welder that has a 100% duty cycle at 300 amps or more, and you get in real close to the work and then weld until your gloves are smoking, the optics in your helmet will malfunction---but they'll come back after it cools for a few hours. All the best, Stan
