Pot Metal Repair?
TMAC
08-07-2001 17:55:26
A mounting tab on the oil filter housing of my Farmall F30 is broken. This appears to be 'white' metal or pot metal I have heard about. How can I repair it? I have a oxy-acetylene torch but isn't the melting point of white metal too low for brazing?
Janet Dunn
01-15-2002 13:19:46
 Re: Pot Metal Repair? in reply to TMAC, 08-07-2001 17:55:26
I'm looking for a glue or some kind of bonding material to attach a broken piece off of an antique mirror frame. The frame is made of pot metal with a open schroll work design. The piece that is broken off is also a leg if you want to use the mirror as free standing. I would be statisfied just to get it glued on and hang from wall rather than free standing. Any suggestions?
Steve U.S. Alloys
08-08-2001 06:34:20
Receiving a referral and vote of confidence from someone as competent and knowledge as Mark KW is truly a complement of the highest form.
Thank you Mark.
I do have a good repair product for you TMAC. Our #328. The bond temp of our #328 alloy is 799�F and if the part you have is a zinc die casting and not Al, the melting point of the base material and the filler metal will be virtually the same.
Here's a way to outsmart the die casting that should work pretty well for the shape of the part you need to repair:
Sand the area clean and if you brush it, use a stainless brush. Place the vee'd out and clean part in a firm bed of damp sand. This will form a sort of mold should the metal temp get away from you. Using an ordinary plumbers propane torch, heat the metal and the rod at the same time. Stir the rod against the metal as temps rise and 'paint' the rod on as both metals begin to blend.
Pot metal is not really difficult to repair but is the the most challenging due to the close relation of the liquidus state common to both materials. Repairing aluminum is practically fool proof.
If you do try using my material and experience any difficulty I will be glad to make the long distance call to offer assistance. If you are in an area close to a rep we can send him if you want. In any case, if won't work for you we'll take it back or swap it out. I'll include a link if you want to read about it on our site.
Joe Helias
01-07-2002 15:06:12
 Re: Re: Pot Metal Repair? in reply to Steve U.S. Alloys, 08-08-2001 06:34:20
I'am trying to repair the tail light housing on a 1964 Pontiac GTO. The Pot Metal has pits in it.
I grounded the raised metal flat but there are some pits I need to fill in. Would like to know what to use. Thanks Joe Helias
Mark Kw
08-07-2001 19:18:28
Esab has a product called Sealcore 5 that is similar to what the other guy talked about. Works OK for some stuff and is relatively easy to use. Cleaning the parts is the most importent step of the process. You can call Esab at 800-ESAB-123 (think that right) and they can give you step by step instructions.
Steve from US Alloys may also have a product for this use and in all honesty, I'd go with Steve's over any others just because he knows what he's talking about and is a strait shooter.
Ford Man
08-07-2001 19:13:25
Tractor Supply has something a lot like the Alumaloy stuff you see on TV .
I tried it on aluminum with a propane torch and it worked great .
Give it a shot and let us know what happens .
Ford Man
