Tool Talk Discussion Forum
Sandblaster
ACMAN
01-29-2008 18:28:58
I have a 10 gal blaster from Rural King using sand to clean Cub. It seems to plug often maybe at lower valve is there a trick to adjusting this or wrong sand. It is dry sand. Thanks.
joelrand
02-01-2008 16:31:32
 Re: Sandblaster in reply to ACMAN, 01-29-2008 18:28:58
I've been using a garnet abrasive from tsc with good results.
Goose
01-30-2008 06:54:23
What kind of sand are you using? Regular sand blasting sand will plug mine, too.
I started using silica sand as it's finer. Costs about a buck a bag more, but it saves a lot of headaches.
paulatclf
01-29-2008 19:25:56
Did you pre-screen the sand? there's quite a bit of grain size variation in your average bag of sand. I use a baker's sifter.
IH2444
01-30-2008 09:58:32
 Re: Sandblaster in reply to paulatclf, 01-29-2008 19:25:56
Screening Yes, otherwise mine plugs. also the moisture trap.
John - OH
01-29-2008 18:50:25
A water trap on your air line is a must. Moist air will defintely cause it to plug up.
