Tool Talk Discussion Forum
Snap-On Wheel Balancer
Glenn FitzGeral
01-28-2008 14:13:21
As many fo you know, I have been loking around a bit for a used wheel bubble balancer for use in my home shop
In calling around I spoke with a fellow who has a Snap-On balancer in which you "mount" your tire on an axel which has a bearing on each end. The heavy end naturally rolls to the bottom. He said you then measure and divide the wheel into three parts, and somehow determine the light spot on the wheel. You then mount a lead weight.
The fellow said it works very well (actually more accurate than a bubble balancer) but is not real fast. He has since replaced it with a spin balancer.
He was going to get it out, check it over, and get back with me on a price. He said he thought he bought it new about ten years ago for around $400.
Do any of you have this type of balancer? If so, would you please tell me a little more about it. Are you happy with it?
Thank you,
Glenn F.
trucker40
01-30-2008 13:59:49
 Re: Snap-On Wheel Balancer in reply to Glenn FitzGerald, 01-28-2008 14:13:21
I dont know about the balancer you are talking about,but the bubble type is a lot less money and if you need to take the tire off anyway for either of them,the bubble is probly faster too. There are companies that rebuild balancers and lifts and jacks and they arent as costly as brand new stuff,and you can rent the stuff to see how it works.You maybe could get a rebuilt by Americans balancer,rent it for a few months,buy it if you like it.If you use a balancer a lot,like in a tire shop,a spin balancer is fast.You might get lucky and get one for 4 or 500 dollars.I will try and find out the name of that company that rebuilds them.
trucker40
01-30-2008 14:17:20
 Re: Snap-On Wheel Balancer in reply to trucker40, 01-30-2008 13:59:49
800-262-1950 for a 89 dollar bubble balancer.Same place has a tire changer and a spin balancer for 1900,but thats not the one I was looking for.Look hard,Snap On really only makes hand tools.The other stuff is made for them and their name put on it.Because of their name being on it they raise the price.Its not any better than the stuff the company that makes it for them sells.
Ralph - Ohio
01-29-2008 05:28:49
I did something similar to this on a trailer wheel that wouldn't fit on my bubble balancer. First loosened the bearing so the wheel would spin freely, found the heavy spot when it went to the bottom, added a weight at the top, spin again to determine if too much or too little weight and adjust accordingly until there is no "heavy spot" - the wheel stops at random locations when spun. Now, why do this on a trailer tire? Because it was so off-balance & the trailer was so light that it was "hopping" at high speed.
If you get this balancer, I'd like to hear the official non-shade-tree-mechanic method that Snap On tells you to use.
Flying Dollar Farm
01-28-2008 16:56:51
Glenn I have a bubble balancer I bought at Harber Freight. Don't use anymore, would you be interested in it. I live near Green Bay, WI. Phone # 1-920-863-6742.
johnski
01-28-2008 16:33:30
Glen, I haven't used the car type of those balancers but they have been using the same style of balancer on motorcycle tires for years and most shops still use them. It may be slow but with a little practice you should be able to get very good results. Another plus is that you will be able to see any runout in the tire or wheel. HTH Jf
36 coupe
01-28-2008 16:05:02
I used one in the mid 50s.It worked fine but I cant remember much about it. The wheel was balanced on the car .I had to slack off on the brake shoes on some cars.
