Tool Talk Discussion Forum
4.3 V6 waterpump R+R
DCM
01-27-2008 20:56:23
Are there any things to watch for in a waterpump replacement on a 97 Chev Astro,has AC.Looks straight forward.Suggestions?Thanks Dan
bradk
01-28-2008 05:47:40
 Re: 4.3 V6 waterpump R+R in reply to DCM, 01-27-2008 20:56:23
Do you have the large wrench and holding fixture to remove clutch fan? You're gonna need it.Some auto parts stores will borrow it to you when you buy their parts.
BTW,counter-clockwise to remove.
Eddie in MI
01-28-2008 03:10:00
I don't have experience with teh 4.3, but when I did it on a 5.7 V8, it really was a straight forward as it looked. I know that both engines are similar - that is why I replied. Just make sure that you find teh torque specs for the WP bolts so that you don't have leaks....
onefarmer
01-28-2008 05:36:41
 Re: 4.3 V6 waterpump R+R in reply to Eddie in MI, 01-28-2008 03:10:00
4.3 is just a 350/5.7 with two cyls missing so it is the same. Pump is held on the block with four bolts. Just remove clean the gasket area good and install the new pump. I like a little blue permatex on the gaskets, but that is up to you.
