Tool Talk Discussion Forum
ideal flame in an old gas furnace?
circus
01-26-2008 21:51:53
Only I would dismantle a working furnace when it's -15 out. Just cleaned and inspected my old fashion gas furnace (G12 Lennox). A lot of burner air gives a bright blue flame that's tight to the burner. A little burner air gives a lazy bright blue flame topped with dark blue streaked with yellow. I assumed the correct flame would have about a � " bright blue flame with dark blue just barely having no yellow. What is the ideal flame in an old gas furnace?
RusselAZ
01-27-2008 17:16:28
 Re: ideal flame in an old gas furnace? in reply to circus, 01-26-2008 21:51:53
Any yellow is to much. Yellow is what soots up the combustion chamber.
Plus, yellow is a waste of fuel.
msb
01-27-2008 12:49:07
Electric blue-no yellow at all.
guido
01-27-2008 06:50:14
 Rg: ideal flame in an old gas furnace? in reply to circus, 01-26-2008 21:51:53
Hey Circus.
You did it wright. I agree with dcotton4.
Just a hint of yellow is O.K. clear blue flame with no yellow is better.
Guido.
dcotton4
01-27-2008 05:43:35
You are correct that you want to adjust the air so that there may be just a hint of yellow on the very tips of the flame but mostly blue and that there is enough air to just lift the flame off of the burner a bit. To much air will make the flame dance above the burner.Also if the air is properly adjusted you should have a nice ignition and not a boom when it lights. Dave
