Tool Talk Discussion Forum
JD clutch tool
cdv
01-26-2008 14:47:27
looking all over the net for a JD 46 clutch tool in think there made by OTC any one know were to look thanks cdv
carman
01-27-2008 19:47:20
 Re: JD clutch tool in reply to cdv, 01-26-2008 14:47:27
working a JD 1050 dual clutch the tool i need is a otc jdg-49 dealer said I think it a jd-46
jdemaris
01-27-2008 06:45:43
Which tractor and which dual clutch? Deere changed the number on those gauges many times, so there many be several tool numbers that do the same thing. Deere used to give us specs on them to make them ourselves - or we'd buy the ones made for Deere by OTC. As the gauges got newer, they were made for multiple use and often one gauge took the place of three old ones.
If it's the finger-height gauge - you can adjust without the gauge by carefuel measurement - or - just go to a Deere shop that knows old tractors (good luck!) and trace their gauge onto cardboard and make your own.
CRUSADER
01-26-2008 17:41:35
Have you checked ebay? There is/was a couple of them there, just put in "John Deere Tool" Are you needing the alignment tool or the adjustment tool for the dual clutch?
Jim
Mike M
01-26-2008 17:09:50
Have you tried ebay ?
I think that is the tool I went to my dealer and made a tracing of it and then made one out of steel from the tracing.
Greg_Ky
01-26-2008 15:20:50
If you know what size they are follow the link and scroll to the bottom of the page
Greg_Ky
01-26-2008 15:26:19
 Re: JD clutch tool in reply to Greg_Ky, 01-26-2008 15:20:50
The CTA Tools can be purchased on-line at the link below.
cdv
01-26-2008 15:08:01
close but I need it for dual clutch thanks
Greg_Ky
01-26-2008 15:11:51
 Re: JD clutch tool in reply to cdv, 01-26-2008 15:08:01
Have you tried the OTC site?
Greg_Ky
01-26-2008 15:03:16
How about this:
