Tool Talk Discussion Forum
LB White problems
Butcher
01-24-2008 10:49:51
Its 5 years old. Green Gro 120 plus. Over the last 2 years the heat output has dropped quite a bit. Now it is giving off fumes and I am sure alot of carbonmonoxide. I have cleaned it with compressed air and cant see anything out of the ordinary. � of the flame is blue and the rest bright yellow. This heater is in a green house at work. I need to get it working befor spring. I certainly wont use it till its fixed. Any sugestions?
kidbob
01-25-2008 19:05:22
 Re: LB White problems in reply to Butcher, 01-24-2008 10:49:51
Yellow flame means the air flow around the orfice is restricted,
JMS/.MN
01-24-2008 17:30:20
I use a LB White as a portable shop heater, mounted on a caster cart with 100 lb tank. Usually startup in the fall is difficult- always need to take the pilot apart and clean the orifice. Dirt or critters get in there. Good to go for the season.
Greg_Ky
01-24-2008 11:12:47
Would you believe that they have a troubleshooting section in the owners manual?
