Hi LS, The AGA never should have let the term ventless be used on fuel burning appliances as that's not a true statement and confuses people. All though the non-external vented appliance works well, they still have to have fresh air "cross ventilation" to keep CO build up to a minimum therefor they are vented to the outside, just not direct connect vented. Yes they make several kinds of non-fan natural/LP gas heaters but there not as efficient as a heater with a fan. You didn't say how large of shop so were guessing as what to recomend, but as mentioned, the RV industry has a 12v 32kbtu furance for LP that can be converted to natural gas use. The efficiency is approx 85%. Add a PV solar charger and a 12v deep cycle battery and your in bizz for 24/7 operation. In your area tho, nothing beats wood heat as it's so easy to get and will out produce any type of fuel burning appliance for warmth. Maybe Wardner will stop in a recomend his Russian wood stove design. Takes very little wood to produce alot of heat and easy to build. Another is a forced air solar hot water system. Another easy DIY project. In your area, you would need about a 2000gal HW cistern. Parts including concrete about $1000. Avantage is the sun heats the water for free. Trouble free for about 10 to 15yrs before minimum componet replacement is required, ie; pump, sensors, fan motor, controller maybe a inside sand/cement coat to patch leaks. T_Bone
