Tool Talk Discussion Forum
Hot Water Heater Cleaned Out
Gary from Mules
01-24-2008 04:23:32
Just wanted to let you all know that I appreciate all comments on cleaning out an Electric Hot Water Heater. I took my shop vac with a 1/2" piece of Copper tubing taped to the smallest nozzle I had and was able to get most of the deposits out of the bottom. Last time I ignored the build up and the element only lasted six months. I believe the effort was worth. Thanks again to all who replied to my earlier post.
GeneMO
01-25-2008 07:53:18
 Re: Hot Water Heater Cleaned Out in reply to Gary from Muleshoe, 01-24-2008 04:23:32
I used to replace elements about every year or 18 months. We put in a water softener when we built our new house in 1984. I think I have replace one or two in the 23 years.
Gene
john *.?-!.* cub owner
01-24-2008 19:49:20
Get some SandHog elements, they don't fail as bad when the lime builds up.
NE IA
01-25-2008 05:34:15
 Re: Hot Water Heater Cleaned Out in reply to john *.?-!.* cub owner, 01-24-2008 19:49:20
A very good point. Sandhogs are great for lasting a long time, but if you do not keep the lime out they usualy come out real hard, and a real pain. Very good product. I know of one where parts are still in there along with a two foot deep chunk of lime. This water heater would be junk regardless.
tele tech
01-24-2008 13:30:55
NE IA You can't be serious,back in the days of being a service technician I forgot to turn the water off before removing the element. I got such a cold and intense blast of water,I would never forget that.And since you are squatting in front of it the soaking is complete. But that's just me Chris
NE IA
01-24-2008 17:10:25
 Re: Hot Water Heater Cleaned Out in reply to tele tech, 01-24-2008 13:30:55
Sorry, you got wet, but we do it probably a half dozen times a year for folks. A electrician in town told me how to do this probably 1971 give or take. You must hold your other hand over it as you spin the element out. The bigger problem is usualy the element must be taken out after I got it all bent up. I guess I probably do get somewhat wet, just never paid alot of attention to it.
NE IA
01-24-2008 06:55:12
I missed your post I guess. We have real hard water in NE IA so lots of lime build up.
A real easy way to clean electric water heaters if they are in a basment with a drain. Take a three foot chunk of rebar and bend a small hook small enough to go through your element opening.
Most folks drain the water heater and then try to clean, we don't. Shut power off and disconect the lower element and unscrew it. Leave water turned on and reach in and hook the lime. The water will wash the lime out as it exits. We usualy lay a hardware cloth over the drain as some have lots of lime chunks.
While we usualy plumb them for easy of dumping bleach into the heater, now is the time to dump in a gallon of bleach to stop the stink / bacteria.
