Seems you must have a drain on those batteries - nobody's luck can be that bad with bad batteries. If someone tells you that you need some sort of "high tech" gel battery, AGM, etc. - don't believe it. They have their advantages and disadvantages like anything else. The "low tech" flooded lead-acid batteries are very tolerant to abuse and many last a very long time. I've got four diesel trucks, and eight tractors, crawlers, and backhoes that all sit, all winter. If we get a warm-up I start them up for 10 minutes - so maybe they get run twice all winter. Batteries are not disconnected, no float charger used, etc. I've had no problems and all my batteries are conventional lead-acid batteries. Some NAPA (Deka and Exide), some Walmart (Johnson Controls), some Delco, and some Sears Diehard. Out of the whole bunch - I only unhook one Chevy diesel Suburban because it has an analog clock that draws current all the time. I just changed the battery in my IH tractor that only gets used in the summer. I put it in new 1/31/99 and it just crapped out 1/23/08. So, that's 9 years. It sits all winter, every winter without being started. It was just a conventional NAPA lead-acid battery #7235, group 31P, 1125 CCA - and I do nothing to it all winter - I don't unhook it, no float charger, nothing. I just put in another and it cost $92. My 92 Dodge truck with the Cummins 5.9 has the same NAPA #7235 battery that is now 7 years old and it too sits all winter with the plates off. My Deere 1010 crawler (gas engine) has a Walmart battery - cost $39 and is now 7 years old. It too sits all winter without being used. My Case VAC has a 6 volt battery that is now 10 years old and still holds a charge.
