Hi Glenn, As has already been said, the shade lens you need is based on the brightness of the arc and what feels right to your eyes. For instance, my vision is still very good, but my eyes are not sensitive. I generally keep my adjustable auto-darkening helmet turned to the lightest shade, which is 9, and usually forget to turn it darker when I'm welding at higher amperages. But I know people who claim to get headaches even with their helmets set for the darkest shade, and sometimes wear dark glasses under the helmet. The auto-darkening helmets I've used were adjustable, but you had to do it yourself. I've never used one that automatically adjusted itself to the brightness of the arc. I don't think I'd like that feature. Since I usually set my helmet at least a shade lighter than the recommended settings, it seems like a self-adjusting helmet would disagree with me. Maybe there's an override, or a selector. I find it particularly hard to weld in the dark, which makes me suspect that shining a bright light on the work might do a lot to improve visibility. The only time I tried it, though, weld spatter hit the bulb and put it right out. I keep meaning to try it again with a protected bulb, but I only think of it when I'm not welding. All the best, Stan
