HVLP PAINT GUN/SYSTEM RECOMMENDATION
Gino
08-05-2001 11:35:05
Hello, Iam considering purchasing HVLP paint equipment. I want to primarily paint tractor parts and occasionally a whole tractor. Does anyone have any recommendations. I have seen the guns/canisters for sale that I presume I hook up to an air compressor? Are they very hard to use, do they provide superior results, are they hard to clean-up??? Right now I do alot of painting using aersol cans. Thank you !
Cliff Neubauer
08-05-2001 19:52:08
 Re: HVLP PAINT GUN/SYSTEM RECOMMENDATION in reply to Gino, 08-05-2001 11:35:05
My first question for you is how big is your air compressor, most paint guns take alot of air >10cfm. Also how much are you going to use it, if it will only be used ocassionally a cheaper gun will work but if it will be used regulary I suggest a better gun. A lower end HVLP gun will start around $150 and range up to $550. I have a Sharpe Platinum gravity feed HVLP gun, it cost about $345 but it is a professional quality gun and gives very good results. The Platinum uses 7.5cfm, the lowest useage good guns that I've seen. Below is a link to the site I bought my gun from, there is also a good discussion forum on this site where you could get gun recremendations from guys who use lots of different guns. A good paint gun will give much better results than a rattle can, and are pretty easy to clean up. Buying paint in quarts or gallons will save alot of money and the spray gun will be much more flexible.
casiano martinez
04-09-2002 14:14:08
 Re: Re: HVLP PAINT GUN/SYSTEM RECOMMENDATION in reply to Cliff Neubauer, 08-05-2001 19:52:08
dear:to whom it may concern
i have bought a gun from ppg and i lost the list of the paper that came with the gun .I do not now what is the recomendation preasure for the gun,
all i know is that it is a hvlp sharpe gun siphon gun and that it says on the gun the max is 35-45 and it light blue,could you tell me what is it that im doing wrong because i have shot this gun before but do not know the recomendation of the gun.I shot it the way i was thought at school and that is 90 on the compresor and 6 on the gun, i open the mouth of the gun between 6-8 inch and the amount of the material at a good amount but it came out doll but i shot it close and not far, i want to know what would you recomend ,for me to do. what is it that im doing wrong?or that the gun need to be shout at the gun recomendation or is it okay for me to shot it like i was thought and it wont damage my gun because the tip is made up of steal. thank you for you time!
Tony
08-05-2001 13:10:23
I recently purchased a HVLP gun to paint pedal tractors with, i recommend them to anyone. You hook them to your compressor, you'll want a moisture trap and a regulator at the gun. for mine turn the pressure down to about 15 lbs. They clean out real easy, just run some thinner through them. the results are amazing, hardly any overspray. Tony
