Tool Talk Discussion Forum
Static on CB Radio
KCTractors
01-21-2008 20:41:25
Just put in a Uniden CB radio in a 1998 Mack CL truck (460 diesel). I am getting static from something, probably the alternator, because the static gets faster as you increase speed. It also gets static from the windshield wiper motor. What would be causing this problem? Anybody know of a place that would fix 29 year old Motorola CB radios? This radios worked beautiful, but I think the Mic wires broke. I know I can buy a new radio for less money, but I really want these fixed. I have two of them.
dave guest
01-23-2008 17:02:43
 Re: Static on CB Radio in reply to KCTractors, 01-21-2008 20:41:25
Like steve a w says. We used to run positive and negative wires all the way to the battery.
fixerupper
01-22-2008 19:27:52
We've had that same problem with and International 9300, only it's a whine. Anytime an electical connection is loose anywhere on the truck the radio will whine. Usually it's a bad ground somewhere but one time it was corroded battery cables.
Sometimes a bad antenna or radio ground will make it pick up static from fan motors etc. Jim
trucker40
01-22-2008 17:14:55
Lot of times it needs a good ground on everything.Cabs being made out of fiberglass causes stuff to happen,and the way things are wired doesnt allways get a ground to ground.For about 30 dollars you can get a new radio,but maybe it wont work either.Seems to me that the south had the best radio repairmen when I was trucking.I dont know where you are,but if you could get to Mississippi or down in there,Alabama,Kentucky,Tennessee,you maybe could get it fixed at a cb shop cheap.
soundguy
01-22-2008 12:31:16
Try a PI filter right at the cb.. IE.. capicitor, inductor, capacitor.. put the inductor inline with the power feed, and an electrolytic cap from the power line over to the ground line, on either side of the inductor. pay attention tot he polarity ont he electrolytics. i also like to install a couple ceramic discs in parallel with the electrolytics.
I also install a pair of electrolytics with a ceramic disc right at the alt power stud, and at any offending motors.
( I used to make kits for the local PD that used hi-output alternators that made fuzzy noise on their radios.. always worked like a charm.. )
The higher value of the electrolytic the better.. minimum of 1000uf.. though i have used 6800uf ont he alt.. with usually 2200uf on the other filters.. occasionally 4700uf at the radio .. especially if there was a linear involved..
works good on ham rigs too.
de ke4rrd
73's
Soundguy
JoeK(WI)
01-22-2008 08:18:37
12V lead wires are not shielded and can act like an antenna,picking up static.Route them away from other wiring,wrap em with foil,or use a piece of coax or shielded cable for the power lead.(Old CBers tricks).
CB repair guys still exist,but fairly scattered,might try Google search for"CB Repair".
mj
01-22-2008 05:58:52
Does it go away on a wet road or at very slow road speeds? If it does, it's static electricity built up by the tires. Go to the hardware store and get some powdered graphite in the small tubes sold for locks. Squirt a tube in each of the front hubs. Sounds strange but I did it on all the big trucks I used to drive and it works like a charm AND I never lost a wheel bearing.
mj
01-22-2008 06:01:08
 Re: Static on CB Radio in reply to mj, 01-22-2008 05:58:52
And ..... what all the other boys said as it's probably a combination of all that, too!
36 coupe
01-22-2008 01:03:48
You need a feed thru capacitor on the alternator and the wiper motor.These filters are sized by the amount of current they must handle.The wiper motor filter must be wired as close as possible to the motor.The heater blower motor will need a filter.
rockyhawaii
01-21-2008 22:09:35
A filter is (or was) available at Radio shack. Can't say how well it worked.
Kentb of SWMO
01-21-2008 21:50:48
I have seen alt. whine caused by a bad diode. Also be sure ALL of you grounds are good including where the ant. is mounted.
Kent
s.crum
01-21-2008 21:08:31
CB radios are still around?
ericlb
01-22-2008 20:39:54
 Re: Static on CB Radio in reply to s.crum, 01-21-2008 21:08:31
around and still indespensible, there in every big truck on the road, thankfully a lot of the jabbermouth idiots on base stations have moved or lost interest, so we can talk business now
s.crum
01-22-2008 21:00:21
 Re: Static on CB Radio in reply to ericlb, 01-22-2008 20:39:54
We used to have CB radios in the trucks and backhoes. They were quite handy. The one I had in my truck I took it out and gave it away after we sold out because of all the trash mouth that was on it. Replaced it with a BOSE stereo just before cassette tapes became extinct.
Steve A W
01-21-2008 20:59:00
Try running the power line strait to the battery.
36 coupe
01-22-2008 00:56:51
 Re: Static on CB Radio in reply to Steve A W, 01-21-2008 20:59:00
This sounds like a good idea but corrosion eats the connection off in a short time.Radios connected this way are often left on.runnig the battery down.
