Tool Talk Discussion Forum
rotten egg smell under the hood?
RobMD
01-21-2008 16:18:20
My 99 ranger pickup smells like rotten eggs when you open the hood up. Nothing looks abnormal under there. Wonder what it could be?
ken in texas
01-22-2008 09:17:48
 Re: rotten egg smell under the hood? in reply to RobMD, 01-21-2008 16:18:20
Be VERY careful ,overcharging battery produces hydrogen gas. It smells like rotten eggs,and is very explosive..... ..... .....
T_Bone
01-21-2008 19:38:56
My daughter came home one night and told me a sherriff had pulled her over as her cars exhaust was glowing cherry red.
The kitty was plugged up pretty bad. I'm surprised it even ran.
My vote is for a bad voltage regulator.
T_Bone
Harvey3
01-21-2008 18:25:16
Rob you may have had a rodent crawl up there and die.
01-21-2008 18:19:58
If you open the hood and it smells, better check the alternator output. It sounds like its dumping more than 14 volts to the battery. The smell comes from the vent on the battery itself. It will go away 5 to 10 minutes after you shut the engine off. Cat converters can put out the odor, but its not from under the hood.
JT
01-21-2008 16:41:03
Could be a battery overcharging or a plugged up catalytic converter. I have been told if the are plugged or bad they will smell like rotten eggs, something else to look at,
Jim
135 Fan
01-24-2008 12:09:27
 Re: rotten egg smell under the hood? in reply to JT, 01-21-2008 16:41:03
I agree on the catalytic converter. The rotten egg smell is the indication that it is plugged up and needs replacing. Check with a muffler shop. Not cheap however. Dave
Greg_Ky
01-21-2008 16:21:58
Sounds like the battery is over charging.
RobMD
01-21-2008 16:38:22
 Re: rotten egg smell under the hood? in reply to Greg_Ky, 01-21-2008 16:21:58
Uh oh... I better break out the voltmeter... thanks.
36 coupe
01-22-2008 01:12:36
 Re: rotten egg smell under the hood? in reply to RobMD, 01-21-2008 16:38:22
Be careful working on this.I have seen battery caps blown off,bulged battery cases and exploded batteries.You are smelling sulfuric acid.Overcharging for sure.
