Tool Talk Discussion Forum
Black Decker Battery Charger for portable tools.
J Schwiebert
01-19-2008 08:04:00
Anybody know what the voltage should be when charging the batteries (in this case cordless drills) I think this one is a little high. Thanks in advance. J.
RayP(MI)
01-19-2008 15:07:31
 Re: Black Decker Battery Charger for portable tools. in reply to J Schwiebert, 01-19-2008 08:04:00
Depends on the voltage of the battey, and will probably be several volts higher than the battery is rated. Most cube chargers have a output voltage on the case. If you measure the charging voltage on the plug when not charging, it may be even higher than posted on the unit. Sorry, I still didn't answer your question.
NE IA
01-19-2008 09:56:01
I can not answer your question, but beware if it does act up you can start a fire, so isolate it and charge only in a non combustable place. We had a DeWalt 18v charging in a very expensive house with wood planner shavings scattered two foot away. Now all are chargers are in a big military mortar box with lid on when charging. It holds nine chargers so its not a big deal. Sorry I did not answer your question.
