Tool Talk Discussion Forum
Slide Hammer
AWB
01-18-2008 19:30:12
What is a slide hammer? What is it used for?
john *.?-!.* cub owner
01-19-2008 19:35:19
 Re: Slide Hammer in reply to AWB, 01-18-2008 19:30:12
The small ones are great for pulling oil seals.
Stan in Oly, WA
01-19-2008 08:46:00
Hi AWB,
I have a completely different tool which might also be called a slide hammer. It is a steel shaft about 18" long and 3/8" in diameter inside a steel sleeve about 1/4" shorter. The shaft has a weight/handle at one end. It's used to pound nails in locations where there's no way to get a swing with a hammer. I use it so infrequently that I sometimes forget that I have it, and deal with the problem using one of the methods I came up with during the 20 years before I saw that tool and bought it.
All the best, Stan
Grundy (IA)
01-19-2008 19:41:58
 Re: Slide Hammer in reply to Stan in Oly, WA, 01-19-2008 08:46:00
Hi Stan in Oly. You have what we called a "pea shooter." I have one that we used inside of concrete forms to avoid the re-bar. That's what the iron workers that made them called them. Some were fancy and had a tube piggybacked on the drive tube so you could feed a nail in without removing the driver (or tool) from the tight location.
J.C.in AZ.
01-19-2008 08:25:15
I have more than several. Two are dedicated to my Auto Body Restoration Hobby but the most unique one ,I think, is the Tool I made with a slide Hammer and a Nail Pincer. I welded the bottom Shaft part of the Slide Hammer to one of the Handles of a Nail Pincer{cut off tool]. I used to use it to remove the Lead and Neo Headed Nails from Steel Shed Siding and Roofing. Carefully grasp the head of the nail and use the slide action to remove the nail. Works very well and damage to the Metal panel is not noticeable if done properly.
fixerupper
01-19-2008 09:09:09
 Re: Slide Hammer in reply to J.C.in AZ., 01-19-2008 08:25:15
DITO!
Goose
01-19-2008 07:05:01
Invaluable in auto body work. If there's a dent you need removed, but can't get behind, you can tack weld a tab in the dent, then put a clamp on the tab and use a slide hammer to pop the dent out. Then after it's served its purpose, grind the tab back off.
Charles (in GA)
01-18-2008 20:15:55
Very useful tool in certain situations, but also very dangerous if not use properly and safely. Easy to injure fingers if not used with the utmost of care, and gloves.
Along with the hook jaw pullers for bearings, shafts, etc, and the axle flange puller, there is a U shaped adapter that hooks behind CV joints at the transaxle and pops them out. They are usually stuck by an expanding snap ring and need a good jolt to pop them loose.
Charles
Charles
Davis In SC
01-18-2008 21:54:23
 Re: Slide Hammer in reply to Charles (in GA), 01-18-2008 20:15:55
I agree that most slide hammers are real finger busters.... But my OTC slide hammer is designed to make it almost impossible to mash or pinch a finger..
Tom from Ontario
01-18-2008 19:55:15
Captive sliding weight on a rod with an arrangement on one end for pullers, clamps, vise grips, etc, to fasten onto (for instance) a bearing on a shaft where you can't get a hammer or bar behind it.
Consider it a reverse hammer.
Greg_Ky
01-18-2008 20:00:27
 Re: Slide Hammer in reply to Tom from Ontario, 01-18-2008 19:55:15
To go with what Tom said:
third party image
BigMarv1085
01-20-2008 12:45:45
 Re: Slide Hammer in reply to Greg_Ky, 01-18-2008 20:00:27
I have a pair of vise grips that I use with my puller.
