Tool Talk Discussion Forum
DUMP TRUCK HYD. CYLINDERS
lenray
01-17-2008 17:41:37
Just got a dump truck 10 yard that has just one big telescoping hyd. cylinder.
All the trucks I have had in the past usually had two cylinders to raise the bed--or one cylinder in a sizzors arrangement.
Is just having this one big one a good deal????
8n/9n
01-18-2008 19:43:41
 Re: DUMP TRUCK HYD. CYLINDERS in reply to lenray, 01-17-2008 17:41:37
With my uncles truck (a 10 yd mack CH612 6 wheler) it has a 3 stage single cylender, the only problem we have with this one is that if it goes all the way up when you lower it it will slam down a few inches at the top.
J Heitkemper
01-18-2008 19:53:05
 Re: DUMP TRUCK HYD. CYLINDERS in reply to 8n/9n, 01-18-2008 19:43:41
Need More details ,, But it Sounds like there is AIR TRapped in the cylindar,, Should be a Hand tight Bleeder screw at the top of Cylindar ,, I would lower the bed to do this for safety SAKE , However it can be done in the Up position , Be Careful ! Jim
old
01-17-2008 20:41:42
Thats the way ALL of the big boys trucks are set up. 99% of the dump trucks used for road constrution are that way and they work very well.
ericlb
01-17-2008 19:12:21
all my dump trucks have 1 single cylinder, i would never ever own a twin cylinder job, if a hose failure occurs and it will, the single cylinder will come down fast and scare you , if that happens on a twin cylinder only one will colapse, which will cause the truck to roll over, and at the least tear up the truck at the worst it may kill somebody
Greg in Mo.
01-17-2008 17:55:15
Thats a pretty typical set-up. Most end dumps have a 5 stage cylinder, and the dump trucks have either 3 or 4 stages.
RobMD
01-17-2008 17:48:28
Dual cylinders are nightmares.
