Well, as the title above goes, figured I'd finally fire up the woodstove in the cellar again, don't think it's been used since the late 70's-mid 80's. This chimney has it's own clay/brick type flue maybe 8"x12", the ones for our fire places are like 24" x 24" huge, they never get dirty, neither was this one, there was some creosote towards the bottom. I remember the house being built when I was much younger, not sure what happened with this flue, but it's crooked, it has a bend in it, towards the bottom, before it turns 90 degrees inwards towards the sleeve in the foundation, so you can't see to the bottom from the top, like the fireplaces which are so nice with over sized flues. From the inside at the cellar, it also has a bend in it, so it's hard to see to the 90 degree turn to the top, but I did get a work light in there and could see the 90 degree turn up. I'm not sure what could be in there, and I think it's not that far from the 90 degree turn at the bottom, (figures it's the hardest place to reach from both directions !) and aside from trying to understand why they installed 1/2 of the flue at an angle so you can't see anything below the bend, it would have been fine if they just came up straight, it's like they did it in spite, were drunk or there was a major problem that I just don't see. I'm wondering what kind of tool might be good to break up the blockage. No idea what it could be, probably spalled pieces of flue tile, creosote, and I hope nothing else in there like bricks or anything, there were some decorative pieces on top of the chimney that are now loose, earthquake in '02 rattled a piece off one corner, so it's hard to say for sure, but it can't be like someone poured mortar or concrete in there. Dropped a light as far as it would go, and could not see light from the other side, pushed a light in and up at the 90 upward in the cellar, no light seen from the top, and does not seem to have any draft when you put smoke in the foundation sleeve a the bottom, sealed up nicely it seems. At the time I'm writing this, I remember having some 1" galvanized well pipe in my material yard, and I think I may have enough room and bend in the pipe to get it down there, the heavy chain with a large hook did nothing even with a few feet of free fall,(that is a work out !) I might have to clean some galvanized coating off and weld 2 sections together, any suggestions for the end, leave it open as is or I could weld something on it. Looking for ideas, figured I'd have been done already with a nice fire going LOL !
