Tool Talk Discussion Forum
To kidbob and other STARTER wizards
Tom43
01-17-2008 12:37:17
Dear kidbob,
You said you have worked on starters and generators for 30 years. How do you check starter fields for shorts? They can easily be checked for being open or grounded to the case with an ohmeter but the ohmeter is not sensitive enough to pick up a short in the heavy starter windings. Also, I have had trouble picking up shorts in a starter armature on a growler as opposed to a generator which has both more and smaller windings.
kidbob
01-20-2008 19:31:35
 Re: To kidbob and other STARTER wizards in reply to Tom43, 01-17-2008 12:37:17
Electrical repair is only a part of my business, and I don't have the expensive tools of a rebuilder either. On a starter the only other test I do is look for signs of overheating. On armatures the varnish will have little blisters on it if it has been to hot. I answered the other post because I have a lot of old small parts if some one needs some.
