Thrush Bearing Follow-up
krum
08-02-2001 06:33:30
Thanks to everyone that responded to my previous question about locating thrush ball bearings. I found the thrush bearings that I need. When I first called my three local dealers they all said that they could not get the size that I needed. I decided to take the remaining parts (after I torched them) into one of the shops to see if we could work something out. I told the man at the counter what size that I measured and he told me that I was wrong with out even measuring the bearing. Then he told me that all bearings other than bearings used for agricultural purposes are measured in metric. About this time I was wandering why they didnot question me about the size that I was requesting and he told me that I didnot ask so they didnot pursue it further. Well I have the new bearings on order so, from now on I'll know to measure bearings in metric.
There was a question about what a thrush bearing is. The best I can tell you is that a thrush bearing is made to take the force from the sides. The bearings that I'm replacing are on a merry-go-round and look like normal ball bearings but, because the shaft is verticle the (thrush)bearings need to support the weight from the sides.
I think you mean thrust, not thrush
08-02-2001 13:34:08
 Re: Thrush Bearing Follow-up in reply to krum, 08-02-2001 06:33:30
Hi Krum,
I was wondering when you posted if maybe it wasn't metric. What you describe sounds like either a ball thrust bearing (i.e. taking load along the axle) or an angular contact ball bearing (able to handle thrust and radial loads). These are almost all only available in metric sizes in the size range you mentioned. However, a tapered roller bearing will also handle axial loads (usually more than a ball thrust or angular contact ball bearing) and they are available in both inch and metric sizes. I'm not sure I know what you mean by taking loads from the sides, as it seems you need to take the loads from the end of the shaft. A regular ball bearing takes the load from the sides. I'm glad you were able to get the bearing you needed.
