Tool Talk Discussion Forum
C' Aire Air compressors
jdjack
01-15-2008 11:35:17
I have been looking around for air compressors.
I am looking at a C'Aire 2 model ct580v282.
Anybody have any feed back on these.
2 stage, 5hp, 145-175psi, 80 gallon, 16scfm@150psi.
I have a da sander, buffer wheel, cut off tool, 3/8 1/2 impacts, air hammer, 1/2 air drill, ratchets all snap-on and mac. This is just hobby work that compressor will be used for.
RickL
01-16-2008 06:04:59
 Re: C' Aire Air compressors in reply to jdjack, 01-15-2008 11:35:17
been running them for several years 7hp model. The first unit went 12-14 years before had melt down,kept tank anhave another C aire 7hp tee in to old tank now running with two 80 gallon tanks,runs everyday all year around in shop assembly equipment. Keep oil change and drain moisture they wiill run for years. I also rempve the drain petcock and run another 50ft hose out it. gives another outlet to the outside shop plus always blows the moisture out
dave guest
01-15-2008 15:55:52
Sounds okay to me. I do all that with a 4 horse sears. But the proof of the puddin' is in the eatin'. Is it returnable or could be exchanged. That is what I would want to know.
