Tool Talk Discussion Forum
Will my compressor work?
Chelle
01-14-2008 19:38:44
I have a 3 gallon compressor that says .5 cfm @ 90 psi and I am working on finishing basement and need to get a framing nailer, the one I have say 4.1 scfm @ 90psi. For small projects will my compressor work? Thanks
circus
01-14-2008 22:14:56
 Re: Will my compressor work? in reply to Chelle, 01-14-2008 19:38:44
1/2 cu ft is really small. One trick is to add more tank. Useful only if the nailer works at the low pressure start setting.
old
01-14-2008 21:08:42
Thats a yes, no and sort of thing. Yes it will work but it will cycle a lot and you will have a lot of lag time doing your work. Say maybe 5 nails then a 2 minute wait on the PSI to build back up. You can get the job done that way but it will take a lot of time to do so. Now if you could hook up a bigger tank that would speed things up but the lag time would be greater between building up the needed PSI
