Tool Talk Discussion Forum
2 HP. 22 Gal. Sanborn air compressor. Tank
Dave F.
01-13-2008 07:37:45
Well the tank on my good old compressor sprung a pin hole leak. any body know where I can get a replacement tank for an Sanborn model 104A200-22 2Hp. 22Gal air compressor. Thanks Dave F.
JMS/.MN
01-13-2008 13:42:54
 Re: 2 HP. 22 Gal. Sanborn air compressor. Tank in reply to Dave F., 01-13-2008 07:37:45
Weren"t they made by SMC, (Sanborn Mfg. Co.) in Sanborn, MN? If you"re going to weld a patch on it- do the bottom third of the whole tank. Or buy a couple portable air tanks, plumb them together. Or use the air tanks from a semi truck.
JMS/.MN
01-13-2008 14:12:06
 Re: 2 HP. 22 Gal. Sanborn air compressor. Tank in reply to JMS/.MN, 01-13-2008 13:42:54
google Sanborn Mfg co., Sanborn, MN. Have your model number, follow the pages.
Jerry/MT
01-13-2008 12:51:41
I have a Sanborn that sprung leak after 5 years of use and I drained the tank after every use. When I looked for a replacemnt tank it was more than the cost of a new compressor. I found a generic tank a couple of years ago and I am in the process of converting it over to take the old two stage compressor. Found the tank at Surplus Center in Nebraska. $129 plus shpg.
fixerupper
01-13-2008 09:50:05
Do you happen to know how old it is? The reason I ask this is a neighbor bought a new Sanborn 2 HP about twenty years ago, and six months after he bought it the tank blew up. Luckily no one was around when it happened because it literally blew the shop apart. Windows were blown out, doors blown open and tools scattered all over the place.
They don't live far from the factory so they took it back and suddenly there was a recall on that model. They never did say what the weakness was.
I just want to give you a little heads up. Maybe if it's lasted this long it's OK. Jim
rodgernbama
01-13-2008 09:06:14
Think I'd try welding it first before I bought another.
JT
01-13-2008 08:48:20
go to www.powermate.com. contact them from there, Jim
Mark-Mi
01-13-2008 08:41:50
Roll her over and weld a patch on it.Drain the water out more often.
Mark
markiz41
01-13-2008 08:37:53
New ASME tanks cost a mint. Not worth it for an older unit. Try to score a good used tank with a big enough saddle to accomodate your pump and motor.
JoeK(WI)
01-13-2008 07:49:57
Believe Coleman took over Sanborns holdings several yrs ago and now owns the name.Try a Google search for "Sanborn Parts" or "Coleman Compressor Parts".
If you have the manual/Partslist,also try Google search for the tank Part No.
chvet73
01-13-2008 17:53:33
 Re: 2 HP. 22 Gal. Sanborn air compressor. Tank in reply to JoeK(WI), 01-13-2008 07:49:57
Yu can find another used one for less than a new tank.
